DISCUSSION
Electrical
Heat/air only works on full blast?? not on settings 1-3, only on 4
Topic: Heat/air only works on full blast?? not on settings 1-3, only on 4 (Read 2655 times)
AlpineRob
October 26, 2009, 08:48:08 PM »
My heat (ac doesnt work anyway) only works when i turn it all the way up to "4" What is the problem>? Thanks!
monty23psk
Legendary
-Receive: 17
October 26, 2009, 09:04:50 PM »
Either your knob is bad or the motor of the blower, normally it is the motor. Your resitor on the motor is probably shot so only works in the on or off which is the same as #4. You can sometimes replace the resistor.
Alex 88 m5 | 91 318is | 19 Subaru Ascent
Administrator
Legendary
-Receive: 60
Lives in the 80s
October 27, 2009, 09:52:44 AM »
Yep - fan resistor. Pull the firewall cover off & replace the resistor card on the fan housing.
DISCUSSION
Electrical
