Author Topic: Heat/air only works on full blast?? not on settings 1-3, only on 4  (Read 2656 times)
AlpineRob
My heat (ac doesnt work anyway) only works when i turn it all the way up to "4" What is the problem>? Thanks!
monty23psk
  • -Receive: 17
« Reply #1 on: October 26, 2009, 09:04:50 PM »
Either your knob is bad or the motor of the blower, normally it is the motor. Your resitor on the motor is probably shot so only works in the on or off which is the same as #4. You can sometimes replace the resistor.
« Reply #2 on: October 27, 2009, 09:52:44 AM »
Yep - fan resistor.  Pull the firewall cover off & replace the resistor card on the fan housing.
