DISCUSSION
Electrical
cluster problems!!!!!!
Topic: cluster problems!!!!!! (Read 2923 times)
E30choa
October 04, 2009, 10:32:40 AM »
suddenly my cluster stoped working and i noticed my blower also is not working any idea whats causing this problem, as for the cluster the only thing that works is the mph
please help, thanks
carlos318is
Sr. Member
October 04, 2009, 10:50:47 AM »
On the cluster it sounds like the cluster its self they are so unreliable.
In regards to the heater does it work on 1 2 3 4
tntempest
October 05, 2009, 03:32:22 PM »
Does everything but the Tach not work, then it is your SI board. I had problems with both the temp and fuel gauge and it was the ground nut that had fallen off of both of them causing erratic readings.
Administrator
Legendary
-Receive: 60
Lives in the 80s
October 05, 2009, 04:21:57 PM »
Might want to check fuses 10 & 20 if it's all out. There's a electrical troubleshooting manual here somewhere...
http://m42club.com/forums/showthread.php?t=7748
It's either your blower motor or resistor. Do a search on this site or the e30 bimmerforums, it's not too hard to do. Open the hood, pull the inspection plate on the firewall, pull plastic straps apart. R&R as necessary. Resistor pack looks like metal spaghetti, blower motor underneath. Pull firmly to remove.
Last Edit: October 05, 2009, 04:30:07 PM by DesktopDave
E30choa
October 08, 2009, 01:08:02 AM »
it was a fuse:o lol
thanks for the help everyone
DISCUSSION
Electrical
