Author Topic: cluster problems!!!!!!  (Read 2925 times)
E30choa
« on: October 04, 2009, 10:32:40 AM »
suddenly my cluster stoped working and i noticed my blower also is not working any idea whats causing this problem, as for the cluster the only thing that works is the mph
please help, thanks
carlos318is
« Reply #1 on: October 04, 2009, 10:50:47 AM »
On the cluster it sounds like the cluster its self they are so unreliable.
In regards to the heater does it work on 1 2 3 4
tntempest
« Reply #2 on: October 05, 2009, 03:32:22 PM »
Does everything but the Tach not work, then it is your SI board.  I had problems with both the temp and fuel gauge and it was the ground nut that had fallen off of both of them causing erratic readings.
« Reply #3 on: October 05, 2009, 04:21:57 PM »
Might want to check fuses 10 & 20 if it's all out.  There's a electrical troubleshooting manual here somewhere...http://m42club.com/forums/showthread.php?t=7748
It's either your blower motor or resistor.  Do a search on this site or the e30 bimmerforums, it's not too hard to do.  Open the hood, pull the inspection plate on the firewall, pull plastic straps apart.  R&R as necessary.  Resistor pack looks like metal spaghetti, blower motor underneath.  Pull firmly to remove.
« Last Edit: October 05, 2009, 04:30:07 PM by DesktopDave »
E30choa
« Reply #4 on: October 08, 2009, 01:08:02 AM »
it was a fuse:o lol
thanks for the help everyone
