irratic idle, cuts off
Author Topic: irratic idle, cuts off  (Read 4274 times)
///m42 sport
« on: September 19, 2009, 05:59:42 PM »
This happened suddenly the other day.  The engine suddenly has irratic idle and cuts off unless I keep the revs up.
I checked hoses (replaced last summer)
video
http://www.youtube.com/watch?v=NP8ICRDqEXY
http://www.youtube.com/watch?v=zXSTeOm2uZE
nicknikolovski
« Reply #1 on: September 19, 2009, 07:18:29 PM »
Idle Control Valve - happened to me as well, crappy idle with rpm gauge fluctuating and then engine justs stall.
///m42 sport
« Reply #2 on: September 19, 2009, 07:35:14 PM »
No, I replaced it with a brand new unit yesterday.  No change in symptoms.
CL4RKY_318IS
« Reply #3 on: October 01, 2009, 11:27:57 PM »
throttle position sensor. get it plugged in and see what errors the ecu chucks up. mines doing this im sorting it today the tps is telling the ecu the engine isnt running at idle speeds because its failing. this causes the ecu to stop the fueling which makes it cut out
roundel318
« Reply #4 on: October 03, 2009, 12:26:40 AM »
I was able to replicate this the other day for someone on another issue with the TPS. Unplugging it resulted in this behaviour.
///m42 sport
« Reply #5 on: October 04, 2009, 02:40:22 PM »
where is it located?
btw the car runs now but gets terrible mileage and poor responsive on the throttle.  Idle is steady.
1991318is
« Reply #6 on: October 04, 2009, 05:46:20 PM »
Quote from: ///m42 sport;79400
Its the black plug on the side of the throttle body. Hope that gets it all fixed. My guess would be hoses, but since you checked those I got no idea.
cravo
    • http://spaces.msn.com/members/cravoportugal/
« Reply #7 on: October 04, 2009, 06:39:24 PM »
Same thing is happening with my 89iS...
Replaced hoses, TPS and Idle valve and still the same... i think it´s possessed by some demon... :D
///m42 sport
« Reply #8 on: October 05, 2009, 08:05:24 PM »
hmm, well I just ordered a new intake boot and throttle position sensor.  Will update once installed.
///m42 sport
« Reply #9 on: October 10, 2009, 04:14:58 PM »
ok I replaced my tps and intake boot.  No change.
dinu.negrean
« Reply #10 on: January 31, 2010, 10:43:57 AM »
Any updates on the matter?
vibefm
« Reply #11 on: May 08, 2010, 01:11:56 PM »
Hi,
I have a 1993 318is 1.8 and have the same issues but i also get my throttle sticking at 1600rpm when the engine is hot?? anyone else had this and has anyone taken the BMW to a main dealer to be checked over on the diag computers
