just unscrew one, if oil squirts out, its the oil pressure sensor. If coolant squirts out, its the coolant temp sensor.But thanks, johnwoo, for the pic, until now, i didn't know where the sensor was located.
One sensor is oil and other coolant. I know this and many do as when if you swap them, the oil light stays on and the needle is dead. It happened to me when I installed everything after rebuilt. There is another coolant sensor the the computer I believe. Just can't remember where. Normally it is on the exhaust side of car, but for what you are troubleshooting, irrelevant.
ok dudes, i installed the new water pump and new sensor, no change at all. Well, there is no more coolant leaking out, but still the same situation with the needle going almost to the 3/4 mark, and the really bad cold idle.
