UPDATE PAGE 6
ok guys here goes:
So i have been having cooling problems for a while now with my 318is, i replaced the mechanical fan with a volvo fan, and that helped, but up until now, i have been running without a thermostat.
So i put in the thermostat today, and after alot of revving the engine and putting coolant in, i got it to work, sort of.
My question is, with the 88 degree T-stat that i got from Pelican Parts, is the temp gauge supposed to be between the halfway and 3/4 mark? that seems a bit high, since when i first bought the car, the gauge stayed a little below the halfway mark.
Also, i had major issues getting the coolant to flow again. Was i doing it wrong? i had the car on a slight incline, and i filled the reservoir, and as i revved, coolant came bubbling and overflowing and spurting out of the reservoir (cap off of course.) so i capped it, and then opened the bleed valve. Nothing but steam came out for the longest time, and then i killed the engine, and removed the bleeder valve completely. Steam came out for a long time until the pressure finally subsided.
Then the reservoir was empty, so i filled it, closed the cap, and ran it again. Then as i started to unscrew the cap, i could see the water level shooting up as the cap relieved pressure.
So anyway sorry for the essay i can never seem to keep these things short, but was i doing it all wrong? what is the step by step process to re-filling coolant once the T-stat has been replaced?
thanks a bunch guys!
