PAPER OR PLASTIC
For Sale
Parting 2x 318is Motors
Topic: Parting 2x 318is Motors (Read 8351 times)
sic///M
August 27, 2009, 07:08:18 PM »
Everything available from DMEs to pistons and accessories. let me know what you need and make an offer
2 cylinder heads are available for $325 each. straight and in drop in shape with camshafts and sprockets attached
set of 6 or 8 pistons for the m20 guys $100 for all 8 or $50 for 4, thats including con-rods
prices are in USD
Located in Toronto, ON
thunder39
August 30, 2009, 09:32:34 PM »
good working icv? Also may be interested in ecu? Or do you just have the blocks.
Birdman16
Sr. Member
-Receive: 1
August 31, 2009, 02:07:16 PM »
Extra front and rear timing cases needed. Also a set of upper and lower oilpans... How much would you like for them if they are still available?
From
The Gumball Rally
Family Rides:
Birdman16: 91 318is (e30) Back from the dead >
Dad: 03 325i (E46)
sic///M
September 07, 2009, 07:20:09 PM »
icv and ecu are available, timing cases and oilpans as well, Birdman16 if you'd like to, send me an offer and specify what you need, ICV and ECU i can do for $50 + shipping
e30sleeper
December 11, 2009, 05:39:18 PM »
hi ill take the 2 oil pans and front timing cover, and oil pump
Last Edit: December 12, 2009, 02:51:27 PM by e30sleeper
carguy101
Reply #5 on:
December 15, 2009, 09:50:59 PM »
how are the guides and chain rails?
richbarn2
Reply #6 on:
December 16, 2009, 01:01:00 AM »
Do you have a serviceable AFM for the M42?
richwrench@gmail.com
Thanks, Rich
dvmotorsports
Hero Member
-Receive: 1
Reply #7 on:
December 21, 2009, 06:52:12 PM »
how much for a 175 DME and one coil pack to 96701?
Chalino
Reply #8 on:
December 22, 2009, 12:31:26 PM »
I need a dipstick; pretty much the tube and measuring wand and any brackets hlolding it to the block.
1991 318is
2001 IS300
fiftytakedowns
Sr. Member
Reply #9 on:
December 22, 2009, 01:38:34 PM »
Crank position sensor to 94903?
clutchkick
Reply #10 on:
December 23, 2009, 07:45:31 PM »
full intake manifold and valve cover to 91901?
ScHpAnKy
Reply #11 on:
December 26, 2009, 04:05:17 PM »
nvm, and good luck
Last Edit: December 26, 2009, 11:52:43 PM by ScHpAnKy
ThaiRacer
Reply #12 on:
December 26, 2009, 08:08:39 PM »
Hey do u have the valve cover bolts? if so how much shipped to 33534
stangimon
Reply #13 on:
December 27, 2009, 09:41:03 PM »
Is that a m42 head. I need one and the side chain guides and crank sproket. Also the waterpump if its ina real good shape.
Thanks,
Dickie
enildeR
lol ur face
Reply #14 on:
December 28, 2009, 12:33:00 PM »
do you have a block, crank and a good oil pump?
PAPER OR PLASTIC
For Sale
