hey all! been a long time since I updated this thread.
the big news was that a small end bush mashed itself - engine had only done about 10k miles. not really sure why. so the engine came out for rebuild no.2 which, although unwelcome, in hindsight wasn't such a bad thing as it allowed me to check and re-measure bores etc. With some new super-strong SE bushes and some nice new lightweight pins, new oil pump, everything balanced again (new pressure plate went in so i did the lot again!) i'm pretty happy. everything was running in great, only small issue was slight hot spots between cylinder walls. Whole ordeal took 2 weeks to sort out.
I put the car back to the standard inlet following this for a number of reasons. the standard inlet is quieter and drives a bit better in the city - it has a stronger idle and copes with high inlet temps better. Also I wanted to devote my attention to my sequential LPG injection project. LPG is under half the cost of petrol over here, has a very high octane rating, and is clean. My setup is now running and I'm very happy with it. its saving me a load of money (car is now as cheap as something like a vw polo in fuel) and is much better in terms of CO2 emissions.
I want to do some more track time, travelling and various other things including more Ring time this yr, so I'm taking a bit of a break from serious engine work for a little while, but there will be more to come. I wasn't able to source ARP rod bolts when rebuilding, but now have a supplier, so I have to have the oil pans off and fit these. I've been weighing up paying somewhere to do the work but I'm not sure. I also want to build another cyl head up at some pt. The current head on the car, although late-spec, low miles, young and fbmwsh, is standard with just re-lapped valves and new gen. stem seals. I'd also like to fit a thinner MLS HG to cure the hot spots and to raise the CR further. Current set of ITBs look like they'll be sold to a friend (dan-318is), so I may have to start on a new setup, learning from the first attempt. The plenum was always intended to be a prototype, I'd like to improve the way the flanges meet with the plenum/trumpets and get the plenum held more firmly to improve the pedal feel. I'd also like to try the advances in MS such as the hi res code.
I've also been working on a few other car projects including a stipped out 2l 8v scirocco on carbs (the chavrocco), a late m44 e36, and soon hopefully an m52 (e36 328i sport) project, although what exactly I'm going to do with the m52 i don't know, but the car is being bought with a fairly large tuning budget in mind. my car is currently the slowest among my closest car buddies, among their cars are a 400bhp audi S4 with 365mm RS6 front brakes, a 300bhp audi S2, a 3 dr sierra cosworth with 300bhp, not to mention the chavrocco which with 110bhp at the wheels will probably give mine a hard time... until the twisties. Still have very little desire to change, the BM is driving great!
Oh and I may be on some dastek rollers next month, but will prob run with the standard inlet.
