Author Topic: Sharp Cam gears, how bad?  (Read 4182 times)
fiftytakedowns
« on: August 06, 2009, 01:44:06 PM »
When relpacing my valve cover gasket I noticed my cam gear (chain gears) teeth were sharp, I know this is quite bad, but wondered How bad, and what I should do to fix it
Is it alright to replace the cam sprokets (sp?), and the timing chain tensioner, and not the chain?
Thanks,
fitty ts
kowalski
  • El\' Duder
« Reply #1 on: August 06, 2009, 01:58:38 PM »
no, the chain stretches to match the gears, and if one is worn, everything is worn. There is also a gear on the crank, which probably matches the sharpness of the cam gears.
Sale:
Fore Sale Thread
fiftytakedowns
« Reply #2 on: August 06, 2009, 02:40:30 PM »
Damn, thats really frustrating.
How long should I run it with the sharp cam gears
« Last Edit: August 06, 2009, 02:49:46 PM by fiftytakedowns »
fiftytakedowns
« Reply #3 on: October 09, 2009, 11:30:07 PM »
Bump:
The teeth were sharp but not horrid,
would doing an m44 timing chain tensioner be a smart move for now.....
« Reply #4 on: October 09, 2009, 11:43:30 PM »
Did you get the 2002 running?
No, don't install the M44 tensioner. It'll just accelerate the wear at this point. Start looking for a swap.
fiftytakedowns
« Reply #5 on: October 09, 2009, 11:58:04 PM »
Ive been at school for a bit, unable to finish the project. Thanks for the info on the m44 timing tensioner.
« Reply #6 on: October 10, 2009, 07:38:49 AM »
Cool man. I can't wait to see that car up and running.
My understand of the M42 timing gear is that the teeth get sharp because of a stretched chain. There is no permanent solution other than replacing the chain, gears and rails and tensioner all together. Replacing just the tensioner now can push a weak chain over the edge.
good luck
Justin
P. Kennedy
Sprockets & chain
« Reply #7 on: October 10, 2009, 11:43:28 AM »
I have virtually new cam sprockets and chain for sale if that would help you out. Though, it's a fairly time consuming task.
fiftytakedowns
« Reply #8 on: October 10, 2009, 02:16:59 PM »
used at all?
P. Kennedy
« Reply #9 on: October 10, 2009, 09:57:24 PM »
Barely.  Couple hundred miles is my guess.  Nice and square at the top of the teeth.  I can send photos if you want.
fiftytakedowns
« Reply #10 on: October 11, 2009, 04:42:12 AM »
how much for chain? I already have the sprockets, do you have any other of the parts?
P. Kennedy
Timing chain
« Reply #11 on: October 11, 2009, 07:32:44 PM »
Well, Pelican Parts want $59 + shipping for it; the st(dealer) wants $135!
How about $40 shipped?
I don't have any other parts to spare.
fiftytakedowns
« Reply #12 on: October 12, 2009, 08:40:44 PM »
Im thinkin about it,
it is used, and usually you want to break in the chain to the rest of the system: and if Im down there I should probably use new parts anyway.
« Reply #13 on: October 12, 2009, 08:50:29 PM »
Order from out of state so you can skip on sales tax. Most vendors should give you free shipping over $50. I think Pelican is in the south bay.
