Author Topic: Sloww 318is  (Read 5066 times)
bosshogg85
Sloww 318is
« on: July 30, 2009, 10:17:56 PM »
Whats up guys? I have a big problem, I drive a 94 318is it looks good but my car accelerates very slow, I have to put it in 3 to accelerate and it still does not feel normal. I get in 3rd gear but I can not go faster than 45 mph. The transmission is automatic and im not sure where to pin point problem. PLEASE HELP ME OUT:confused:
Danny707
Sloww 318is
« Reply #1 on: July 30, 2009, 11:52:17 PM »
Its a 318.
HATER-PROOF
Sloww 318is
« Reply #2 on: July 31, 2009, 12:26:22 AM »
(1)-what grade of fuel are you using?
(2)-do you use additives in the tank?
(3)-has she been sitting in one spot over a long period(months)?
(4)-when was the last time you had her tuned?
Jorgeconrico
Sloww 318is
« Reply #3 on: July 31, 2009, 06:43:21 AM »
Quote from: Danny707;76115
Its a 318.
    ^^^^and an automatic. Fuel filter, plugs.....vac leak
« Last Edit: July 31, 2009, 06:48:05 AM by Jorgeconrico »
iamcreepingdeath
Sloww 318is
« Reply #4 on: August 01, 2009, 03:00:06 PM »
you have to be more specific as to what is actually happening.
bosshogg85
Sloww 318is
« Reply #5 on: August 01, 2009, 03:52:31 PM »
so friday morn when I went to school the car ran like it supposed to,  I just bought the car a month ago I think its been sitting for a good while though. It sounded good when the car didnt accelerate good but friday morn when it sounded a lil like crap it accelerated way better. I have a rattle sound seems like inside the cat and the engine sorta sounds like a diesel. Im thinkin it may be some kinda sensor.
bosshogg85
Sloww 318is
« Reply #6 on: August 01, 2009, 04:00:48 PM »
I use 89 gas and havnt put any addatives in since i first got it
Jorgeconrico
Sloww 318is
« Reply #7 on: August 01, 2009, 05:26:37 PM »
Bad timing chains sound like diesels.
xwill112x
Sloww 318is
« Reply #8 on: August 02, 2009, 12:04:40 PM »
try finding and fixing your vaccum leaks, throw on a new 02 sensor, then see how it runs?
Ich liebe meinen E30
bosshogg85
Sloww 318is
« Reply #9 on: August 02, 2009, 04:09:18 PM »
ok thanks for the advise
xwill112x
Sloww 318is
« Reply #10 on: August 03, 2009, 10:51:57 AM »
yea, get back to us if it doesn't run very well, still.
bosshogg85
Sloww 318is
« Reply #11 on: August 04, 2009, 07:14:48 PM »
checked for vac leaks and put a new mustang o2 sensor and still has slow acceleration and I have noticed that something in the cat is loose and rattles bad. So now im thinking it could be camshaft position sensor or crankshaft position sensor!!
bosshogg85
Sloww 318is
« Reply #12 on: August 09, 2009, 12:31:21 PM »
well I have noticed that the car only runs good when i have a quarter of a tank of gas. fuel filter or pump maybe?
carl6405
Sloww 318is
« Reply #13 on: August 12, 2009, 05:37:36 AM »
Your catalytic converter is probably clogged up and needs replacing. I had to replace mine, it was full of carbon build up. Cant get proper air flow through the exaust will cause this.  The vacuum linese are cheap and can be bought by the foot at any auto store. Also, most are easy to get to. These hoses dry rot and crack.
bosshogg85
Sloww 318is
« Reply #14 on: August 16, 2009, 11:49:48 AM »
yep took my cat off last night and the insides were crushed in big chunks, hooked everything back up this morn its doing good!
