Gearbox woes
Author Topic: Gearbox woes  (Read 2202 times)
spanish_pants
Gearbox woes
« on: July 30, 2009, 01:47:43 PM »
Hey All
It seems i´ve got a problem with my gearbox. Sometimes i can´t engage the gears when the car is on, however when i turn the car off i can.
Has anyone had this happen to them?
I need to take this to my mechanic but i would like to go in having some idea of what is up.
Cheers
Gearbox woes
« Reply #1 on: July 30, 2009, 02:30:14 PM »
Have you bled your clutch?  Do you hear any grinding when you shift?
Could even be really bad engine/transmission mounts.  Don't laugh...I had that happen in an old VW of mine.  The engine would tilt and pinch the gear shifter, making shifting really hard. Wouldn't happen when the engine wasn't running.  I figured that out when the starter died & I had to always park facing downhill...
spanish_pants
Gearbox woes
« Reply #2 on: August 18, 2009, 09:41:18 AM »
I it´s only difficult to engage the 1st and reverse gears but this only sometimes.
If the car is off, there´s no problem. I should probably replace the gearmounts anyway.
Btw, how do you bleed the clutch? :o
3bvert
Gearbox woes
« Reply #3 on: August 18, 2009, 02:26:59 PM »
bleed clutch
get a bentley manual
spanish_pants
Gearbox woes
« Reply #4 on: August 19, 2009, 04:16:08 AM »
Quote from: 3bvert;77040
bleed clutch
is this how you answer every help post?
so much for the sense of community :(
