Author Topic: Broken Thermostat bolt  (Read 6148 times)
BlackBMWs
« on: July 26, 2009, 11:34:49 PM »
Well, a small setback today, in that I broke the thermostat bolt at the 5 o'clock position on the thermostat housing.  The good news is that it snapped off just below the head of the bolt, so I perhaps can coax it out without drilling.  The bad news is that there is not enough wiggle room to get the thermostat housing off.
It's completly loose, but I suspect with all four bolts out, it prolly shifts up to lift off.  With the shaft of the bolt still in place, there isn't enough room to remove it.
Anyway, I shifted to work on other items, but will have to come back to this next weekend.  Anyone have the same issue and a solution?  I did search with no like matches in the forum.
Thanks for any insight...  :cool:
BMWCCA# 160411
KenC
« Reply #1 on: July 26, 2009, 11:49:08 PM »
Move the plastic wire holder...
BlackBMWs
« Reply #2 on: July 27, 2009, 12:16:56 AM »
Quote from: KenCopperwheat;75906
Actually it is unbolted and moved in a later attempt after this photo, although I'll look again and confirm tomorrow.
Does the thermostat housing lift straight off?  I hope it's that simple...
Thanks!   :cool:
« Last Edit: July 27, 2009, 12:21:07 AM by BlackBMWs »
BMWCCA# 160411
BlackBMWs
« Reply #3 on: July 27, 2009, 08:21:12 AM »
Update:  I was hoping it was that simple...  No, confirmed, it is not in the way.  Currently it's about 10mm off the housing and the housing only moves perhaps 1mm toward it.  :confused:
Here's two of the four retention bolts.
I wondered if they are just rusted or if the residue is Locktite red.  Replacing them all, plus the four for the waterpump.
I was thinking about using a lever on the thermostat housing in case it just needs a little nudge, but I don't want to crack the timing case covers.  I'll think about what options exist.
Also, any suggestions for extracting the remaining stud from the broken bolt would be appreciated.  It does look like red Locktite was used on the bolts.   Careful application of heat, PB blaster and a vice grip?
Thanks!
« Last Edit: July 27, 2009, 08:44:01 AM by BlackBMWs »
BMWCCA# 160411
91_e30_m42
« Reply #4 on: July 27, 2009, 10:25:51 PM »
wow i just replaced my thermostat and the bolts felt like they were barley tightened
BlackBMWs
« Reply #5 on: July 28, 2009, 09:23:09 AM »
Quote from: 91_e30_m42;75948
These were in very tight and frozen, which is why I suspect red Loctite was used and over torqued.   Anyway, I'll try to pull the housing off later with a lever.  I'll have about 1/4" of the stud to work with to extract it.  I'll head over to Sears and see what they have to work with in that tight space.
I'll tap the threads afterwards to clean them out.
The water pump bolts were in there vary tight too, but came out intact.  New replacement bolts all the way around.  :cool:
BMWCCA# 160411
KenC
« Reply #6 on: July 28, 2009, 11:56:11 AM »
It pulls straight off. I've done it probably a dozen times.
BlackBMWs
« Reply #7 on: July 28, 2009, 11:35:49 PM »
Quote from: KenCopperwheat;75961
Thanks, I believe you!  However, with a stud in the lower housing, I can move it around, but it dosen't lift off at this point.  I believe the gasket has detached.  Only lifting up about 1mm.
I figure if the stud wasn't there it would lift right off.  Anyway, I'll try again this weekend ;)
« Last Edit: July 28, 2009, 11:55:37 PM by BlackBMWs »
BMWCCA# 160411
MichaelP
Re: Broken Thermostat bolt
« Reply #8 on: August 21, 2015, 01:38:50 PM »
In case anyone else comes searching (as I did) for a solution to this, I'll finish the story:
I broke the same bolt as the OP, in about the same place, and the housing was reluctant to budge. And yes, the housing comes straight off.
Stick the handle of a screwdriver in the left (driver's) port of the housing and give the part of the handle sticking out a good whack with a hammer. If you're lucky, like me, the housing will pop off and land in the tub of coolant that's been draining below.
In my case I was able to just twist out what remained of the bolt with vice grips. Bullet dodged.
Oh, and the replacement for the bolt? it's PN 07 11 9 906 123. And it's $6.00. Six dollars. For a bolt. Cheapest place I found it was at the dealer.
