Update: Only driven to and from work the last 2 days with 8 ounces added as per instructions for our cooling size system. The car does run cooler. Even in stop and go traffic, not a long time, the guage has not gotten to the usual high point but then again my SPAL kicks on at high at that same point with the 80/88 switch. When driving the temp cools down faster.
I wonder if everyone has the same experience with my setup or OEM. I have fan clutch delete, new coolant temp sender for guage and aftermarket Spal 14" fan in place of the OEM aux, using OEM circuit, no added switch or relay. I added the sender after last rebuild 2 months ago, everything else more that a year on the car. My car normally runs from past the 1/4 part of the guage to the a little past half, like a needle thickness or two past half. It has always kept moving since I have gotten my car. I normally see the m20s or other BMWs just sit in the middle and not move around unless during the initial warmup or overheating. I have chaned tstat and water pump plus new hoses and also flush every 2 years. I just wonder if the guage moving is normal. I like the dynamic aspect but want to make sure it is normal.
