Australian and US models are different in a lot of little ways. Most commonly, the M44 is used as an engine assembly with the M42, intake, electricals, and accessories, etc. This is the low cost method. The M44 serpentine belt accessories increases the cost. Most used engines do not come with the accessories. Alternators, A/C compressors, PS pumps, flywheels, etc. are sold separately. It's pretty much hit or miss depending on the source. Swapping over to OBDII is the same as you would need to do with an S50. The cheap way is the only option if you need a motor to put in yourself with 75-100K miles for less than $1K
