Let's talk M44 swap
Author Topic: Let's talk M44 swap  (Read 6419 times)
StreetSpec_iS
Let's talk M44 swap
« on: July 24, 2006, 09:33:37 AM »
Why do people say it is so hard?
Surely it is just a matter of obtaining a complete engine, and swapping it in.
Some people act like it is the hardest swap out there. Surely it must be easier that m/s50.
Ok, so fitment. In theory, this should be a direct swap over, right.
Wiring. With complete harness ecu, in theory, this should also be a straight swap.
Which leaves, OBD2. So what is necessary to overcome this? Converting to OBD1. What is necessary?
What the hell else is missing?
Easy as can be?
« Reply #1 on: July 24, 2006, 01:03:03 PM »
Australian and US models are different in a lot of little ways. Most commonly, the M44 is used as an engine assembly with the M42, intake, electricals, and accessories, etc. This is the low cost method. The M44 serpentine belt accessories increases the cost. Most used engines do not come with the accessories. Alternators, A/C compressors, PS pumps, flywheels, etc. are sold separately. It's pretty much hit or miss depending on the source. Swapping over to OBDII is the same as you would need to do with an S50. The cheap way is the only option if you need a motor to put in yourself with 75-100K miles for less than $1K
« Last Edit: July 24, 2006, 01:11:33 PM by D. Clay »
///Motorsport
Let's talk M44 swap
« Reply #2 on: July 24, 2006, 04:22:58 PM »
im sorry, but what is the m44?  advantages? in what models?  if i did a swap i would surely want to get some displacement out of it...
mgold
    • http://homepage.mac.com/mgold/BMW/PhotoAlbum42.html
Let's talk M44 swap
« Reply #3 on: July 24, 2006, 05:18:30 PM »
The M44 was an updated version of the M42.  I believe it implemented OBDII.
It's a bigger motor!
« Reply #4 on: July 24, 2006, 05:19:08 PM »
Quote from: ///Motorsport
It's the 4 cylinder in later model 318's. The intake and electronics are different and it has a serpentine belt for the engine accessories. If you want a displacement boost, it may be 1.9 as opposed to the current 1.8 (stop it, I'm cracking myself up)
e9nine
Let's talk M44 swap
« Reply #5 on: July 24, 2006, 05:23:13 PM »
ROFL @ D.Clay..
For more info on the m44 - http://www.318ti.org/ You should just visit any e36 or bimmer dedicated site for the breakdown on the little things of variation. I may be the only one who thinks it's not worth to swap to an m44 unless ur m42 shits the bed and u get an m44 for cheap (they can be had for cheap) as a nalmost parallel replacement.
doigal
Let's talk M44 swap
« Reply #6 on: July 24, 2006, 09:41:35 PM »
If you had a donor front cut then i cant see it being any harder than any other swap. If you only got the engine though, then it would be a royal pain in the ass. The advantages of the m44 over the m42 is that 0.1L of displacment and a bit more torque. OBD2 is meant to be a pain to mod as well, but theres a lot of info on generic OBD2 systems out there...
A big reason.
« Reply #7 on: July 24, 2006, 10:07:51 PM »
The main reason for using an M44 is that good, used, low mile M42's are getting scarce.
StreetSpec_iS
Let's talk M44 swap
« Reply #8 on: July 25, 2006, 12:25:02 AM »
^ thats what i was thinking.
Plus, an overbored m44, could be placing you up around near 2.0, when taking into account the slightly longer stroke.
StreetSpec_iS
Let's talk M44 swap
« Reply #9 on: July 25, 2006, 12:26:29 AM »
Quote from: D. Clay
this is what i have asked people before but never got a definite answer.
So, essentially, we can use the m44 block + head etc, to obtain the 1.9 (lol) litres of fury, but maintain our "intake, electricals, and accessories, etc" as you say?
silverblades181
Let's talk M44 swap
« Reply #10 on: July 25, 2006, 10:33:57 AM »
I see no advantage in swapping an M44. M42 has forged internals, M44 doesn't. It has a weirdo intake that gives low end torque but you lose high end power (from what I've been told) and 0.1L increase in displacement is not much. Chip your M42 and voila, you've got more power then the M44. My 2 cents.
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
Let's talk M44 swap
« Reply #11 on: July 25, 2006, 12:26:49 PM »
what about if you used the m44 block to bore instead of the m42 block.  I am probly going to put s50 pistons in next summer but w/ an extra .1L to start w/ I could bore it slightly bigger without risking falures.  I don't know if the m42 head will work on a m44 block though.
nickmpower
Let's talk M44 swap
« Reply #12 on: July 25, 2006, 12:37:09 PM »
ive heard that given equal bores, there is the same amount of cly wall on both blocks
Let's talk M44 swap
« Reply #13 on: July 25, 2006, 01:17:44 PM »
haha nevermind then
///Motorsport
Let's talk M44 swap
« Reply #14 on: July 25, 2006, 04:20:36 PM »
sounds good.  if i did a swap, i would still want to get somethign big out of it... whether it be an s-something or a turboed 4, etc...
