Author Topic: Lighter flywheel  (Read 3340 times)
Janne
Lighter flywheel
« on: June 19, 2009, 09:54:33 AM »
My car is e36 318is with aircondition. Does m20b25 flywheel and clutch-kit pass to my car. Is this good way to get lighter flywheel and clutch packet? I think this stuff is about -5kg lighter than the original doublemass flywheel and clutch kitt.
Lighter flywheel
« Reply #1 on: June 19, 2009, 10:22:41 AM »
I think you can use the E30 M40 no a/c flywheel instead, it's a cheap single-mass alternative.  The M20 flywheel has a different gear pitch so your starter won't work.  Also the flywheel is lighter but the clutch is heavier, you end up saving only ~2kg.
1991 E30 M42
Lighter flywheel
« Reply #2 on: June 20, 2009, 01:20:02 AM »
An m20 flywheel is well worth it, they can be lightened alot, mine weighs 9 pounds, as for the starter, you can have the flywheel machined to accept an m42 starter ring or put an m20 starter gear on your m42 starter. As for an m40 flywheel, I do not know if it will fit. On my other car, I have an M42 non ac flywheel that has been lightened to 17 lbs and it is a very nice set-up.
Janne
Lighter flywheel
« Reply #3 on: September 25, 2010, 08:03:03 AM »
Finally get this m40\m42 solid flywheel 6.4kg. :cool:
http://s303.photobucket.com/albums/nn158/Janne87/?action=view¤t=V-pyr008.jpg
M42_Jester
Lighter flywheel
« Reply #4 on: September 25, 2010, 11:12:51 PM »
+1 very interested in this. looking at doing the same thing...
keep me in the loop :)
deekay
Lighter flywheel
« Reply #5 on: September 26, 2010, 09:13:41 PM »
i went with the M42 non-AC flywheel & a "stage 2" clutch from SPEC last month. 8lb difference and it was a straightforward remove & replace.
johna
    • My BMW 3 Series Website
Lighter flywheel
« Reply #6 on: September 27, 2010, 04:08:28 AM »
A bit of info on the M40 flywheel conversion here: http://www.motortraders.net/groups/group.asp?group=1&menu=1&article=18
