Hi Guys, gotta couple questions. I just got done changing out all my vaccum lines,head gasket,timing chain/gears/tensioner, water pump,thermostat, all the gaskets and seals, clutch/PP etc. I know i need a new back but on to the car. The engine starts up fine, runs smooth and has an awesome purring idle. My first issue is that i seem to have lost some low end HP or torque and i am getting worse gas mileage. I was getting about 28mpg and it has gone to about 20-23mpg. I'm sure i got the timing right but i'm wondering if i should play around with the cam to crank timing. How far can i adjust the cam sprockets before i have to worry about hitting valves? Can i use the whole range of adjustment on the cam sprockets slots? I am thinking that the stretched chain i took off had put the timing in some ideal position that i lost when i went to new parts. Any tips?
Also my car has a very light whining sound coming from the top of the engine. Nothing major but i can't remember if that sound was there before. Kind of sounds like a diff whine and it increases pitch when you rev it. It's not an injector click or anything like that. Does your M42 have a light whine?
Thanks,
Glen
