Author Topic: Couple questions after timing chain job  (Read 3061 times)
BadCab
« on: June 08, 2009, 05:17:31 PM »
Hi Guys, gotta couple questions.  I just got done changing out all my vaccum lines,head gasket,timing chain/gears/tensioner, water pump,thermostat, all the gaskets and seals, clutch/PP etc. I know i need a new back but on to the car. The engine starts up fine, runs smooth and has an awesome purring idle. My first issue is that i seem to have lost some low end HP or torque and i am getting worse gas mileage. I was getting about 28mpg and it has gone to about 20-23mpg. I'm sure i got the timing right but i'm wondering if i should play around with the cam to crank timing. How far can i adjust the cam sprockets before i have to worry about hitting valves? Can i use the whole range of adjustment on the cam sprockets slots? I am thinking that the stretched chain i took off had put the timing in some ideal position that i lost when i went to new parts. Any tips?
Also my car has a very light whining sound coming from the top of the engine. Nothing major but i can't remember if that sound was there before. Kind of sounds like a diff whine and it increases pitch when you rev it. It's not an injector click or anything like that. Does your M42 have a light whine?
Thanks,
Glen
beemer1
« Reply #1 on: June 08, 2009, 05:33:34 PM »
Quote from: BadCab;73274
Thanks,
Glen
The whine is probably a slightly over tightened or brand new belt(s).
When I reinstalled the used chain and tightened everything down I rotated the engine 1-2 times and check that the cams were aligned (w/ cam lock tool).  I had to do that a couple times before I got it just right.  Can't help you with anything else:(
Steve
BadCab
« Reply #2 on: June 08, 2009, 05:49:34 PM »
Thanks, yes it sounds like a tight belt or a power steering pump low on fluid, but in the valve cover.
Well it looks pretty good anyways.
RidingSimple
« Reply #3 on: June 08, 2009, 05:56:26 PM »
Diggin the BRG valve cover!
BadCab
« Reply #4 on: June 08, 2009, 06:08:00 PM »
It's actually Ford Dark Jade. Some Dupliclor spray can stuff. It was the closest i could get to my Laguna Green. It's a little greener than the car but it's really close. I plan on painting the car this fall and will redo the engine parts then. Heres another where you an see the oil filt cover.
B318M42W
« Reply #5 on: June 08, 2009, 10:27:43 PM »
the whine is very possibly the new chain...
as for the gas milage... i have a few things in mind... if all the gaskets are new and everything is sealed up nice, then it might run a little too rich... soo, O2 sensor tired, afm needs a little cleaning/adjustment or the injectors are a little dirty and aren't spraying properly.
as for the sprocket adjustement, i beleive you can do +- 6 deg, but the ECU copes with +-3... but i'm really not sure about thoses #'s... i do know that there's a thread out there that's all about cam adjustement.
M90 Blown M42 :cool:
