Author Topic: 34mpg :)  (Read 6477 times)
///m42 sport
34mpg :)
« on: June 02, 2009, 09:48:36 PM »
My recent trip
195/65 falken ziex
33psi front tires
35psi rear tires
65mph for 220 miles
I thought that was pretty cool for 280k
34mpg :)
« Reply #1 on: June 02, 2009, 10:08:29 PM »
Nice!
monty23psk
  • -Receive: 17
34mpg :)
« Reply #2 on: June 03, 2009, 12:54:52 PM »
cool, how much gas did you start with?
1991 E30 M42
34mpg :)
« Reply #3 on: June 03, 2009, 01:58:48 PM »
When I go to Virginia Tech that's what I average but all of my stuff is different.
Kumho Ecsta SPT 205/55 r15 front 35psi
Toyo T1R 225/50 r15 rear 35psi
310-330 miles depending on any stops
80mph
3.73 rear diff
recently made 180hp on dynojet
34mpg :)
« Reply #4 on: June 03, 2009, 02:03:00 PM »
I'm in the middle of a long trip, so far it's been ~33mpg for me too.  I'm very pleased, especially for 266K.  Summer mix gasoline is great for mileage, and using 91 octane with <5% ethanol (Here in PA they have to admit if there's more than 5% alcohol in the mix).  Our winter mix would give much worse mileage, I'm sure.
40psi F&R 195 14's, 3.73 diff.  No A/C (needs converted), windows closed.  Missing front spoiler makes me wonder how much better I can do.  If only this car had cruise control!
Avg 68mph with drafting a lot of big rigs and SUVs.  Hummers ARE good for something, now aren't they:D.
Be careful not to draft too close - I usually do 30 yards or so...you can 'feel' where the sweet spot is sometimes.  I'm told that it's still close enough to cut air resistance 10-15%.
« Last Edit: June 03, 2009, 02:06:24 PM by DesktopDave »
monty23psk
  • -Receive: 17
34mpg :)
« Reply #5 on: June 03, 2009, 02:59:30 PM »
Not wanting to burst any bubbles but if you are doing 330 miles on a full tank, 330/13 you are getting ~26 mpg. Am I missing something here? Do you guys have a 10 gallon gas tank? The stock e30 91 318is comes with ~13.1 gallons.
1991 E30 M42
34mpg :)
« Reply #6 on: June 03, 2009, 03:14:30 PM »
if i am getting 34 mpg, divide 330 miles by 34 and thats how many gallons i used, simple math, neither of us said we used a tank of gas, we just said the mileage
monty23psk
  • -Receive: 17
34mpg :)
« Reply #7 on: June 03, 2009, 03:35:47 PM »
gotcha, that was the part that was throwing me off. thanks and excellent mileage.
///m42 sport
34mpg :)
« Reply #8 on: June 03, 2009, 03:43:03 PM »
I started with a full tank and filled up when I got home so I know its pretty accurate.
I don't have a is lip either.  Used to but it was torn off by semi tires on the highway
34mpg :)
« Reply #9 on: June 03, 2009, 08:41:27 PM »
Quote from: DesktopDave;72966
Don't convert to R134. Get duracool ;)
34mpg :)
« Reply #10 on: June 04, 2009, 06:10:01 AM »
Quote from: tjts1;72987
Haven't heard of that...so I checked out their website.  How much would you estimate to fix our system?  It's functional, just low on R12.
34mpg :)
« Reply #11 on: June 04, 2009, 08:57:26 AM »
You can mix duracool with R12 so all you need is 2-4 six oz cans, an R134 adapter low side adapter, R134 hose with gauge and a thermometer for the vents. As long as your system holds pressure, you can just dump duracool on top of R12. You should have it going for less than $40.
« Last Edit: June 04, 2009, 09:07:45 AM by tjts1 »
1991 E30 M42
34mpg :)
« Reply #12 on: June 04, 2009, 02:42:11 PM »
duracool is the same thing as hotshot or freeze12 wich are propane or butane based.
34mpg :)
« Reply #13 on: June 04, 2009, 03:31:31 PM »
I don't think so.
Freeze 12 80% R-134a and 20% HCFC-142b.
Hot Shot 50% R-22, 39% HCFC-124, 9.5% HCFC-142b and 1.5% isobutane (R-600a).
34mpg :)
« Reply #14 on: June 04, 2009, 03:43:55 PM »
Data seems a little dicey on these.  I know that the possibility is remote, but pressurized flammable liquids running inches from family & self seems a little dicey.  I'm not sure that r134 would be much more expensive, just a PITA to do.  The sheer convenience of refills and reselling also makes me think R134.  Has anyone done a full retro-fit?
