Dave,
Thanks for that tip. I have tested them with an ohm meter and they all read the same. I didnt put much credit into my test. I will definately go through this test. My coils are all bolted together, and with out the fancy plastic cover that's supposed to be over them. So, I should be able to use the ground that is already there. They are all grounded to the body with this one heavy black cable. Actualy, since my last post, I did some things that seemed to help. We just got back from a nearly 200 mile trip and it didnt stall on me once. But, it seems to me that it is running lean. My mpg is to high, and it is still sputtering a bit. Im getting close to 40mpg. But, when I put my foot in to it and get her up to 80, it gave an occasional sputter, but nothing that made her stall out.
Here is what I did today to it. Re-positioned the coils. Meaning, what was going to plug wire 1 is now going to 4 and so on. Created a new ground wire to the coil pack. Also, ran a 1/2 can of Sea foam directly through the intake manifold and through the system. Poured a can of Heat, water absorbing stuff in to the gas tank. Also, a 1/2 a shot glass of Acetone. My wife was helping me. She discoverd a sensor, under the throttle body that was kind of falling out of the connector. That metal clip on that particular sensor isnt springing back up, and that connector was loose. I think its the "Pulse Generator" sensor. We had to take that particular sensor off when we fixed a prior problem, replaced the oil pump. (That was a whole other thread and big job, then came to find out, it wasnt the pump, but problem was remnants of the prior timing chain guides were laying around in the oil pan, getting sucked up in to the sump.)
So, now, I will check those coils. Autozone, actually has 1 in stock. $79 x 4=ouch! again.
Thanks for the tips.
