Author Topic: Rear suspension noise? Please help  (Read 3853 times)
e30Andym42
« on: May 04, 2009, 09:45:50 PM »
I am not entirely sure what causes the noise to occur, but it generally happens when I make hard right turns.  It sounds like it is coming from the rear driver's side suspension or something.  It is a clunking sort of noise, instantaneous, and repeating itself in the same time intervals.  It does not matter whether I go over bumps or not.  One time when I was driving, it made the same noise while driving straight for a couple miles until I turned.
Sorry for the vague-ness, but I may post up a video some time if my TOB isn't near the edge of death.  Any ideas?  Thanks in advance.
"Objects in mirror are slow"
1991318is
« Reply #1 on: May 05, 2009, 12:39:16 PM »
Check your Rear Shock Mounts. Those are notorious for going out and making a clunking noise.
e30Andym42
« Reply #2 on: May 05, 2009, 03:51:50 PM »
Quote from: 1991318is;71400
Thank you, I will check this now.
e30Andym42
« Reply #3 on: May 05, 2009, 06:00:10 PM »
They look plenty fine to me.  There is a very small amount of surface rust on it, but other than that, looks as solid as new.
renfield90
« Reply #4 on: May 05, 2009, 09:42:21 PM »
I think they can make noise anyway, even if they "look" new.
Mine started making the occasional noise going over the curb to my driveway, but only after I took them out and reinstalled them with new suspension. My noob ass probably installed something wrong though. :rolleyes:
1991 318i
2001 Celica GT
roundel318
« Reply #5 on: May 05, 2009, 10:41:44 PM »
Is this a recourring noise, like a wheel bearing? Does its speed change depending on if you are turning one direction or the other?
The rear shock mounts are the other biggie as seen above.
