Author Topic: Fuel tank replacement....interchangable with 325?  (Read 4524 times)
///M3Mike
« on: May 04, 2009, 08:15:57 PM »
My car greets me with a strong gasoline smell when I go into the garage on some mornings.  I stuck my head underneath as much as I could (lowered) and the side of the tank is damp on the passenger side.  I'm guessing this indicates a tank needing replacement (?).  Can a 325 tank be used or do I need to find a 318i/is tank?
B318M42W
« Reply #1 on: May 04, 2009, 10:23:37 PM »
here's a very temporary fix for the gas smell:
open up the panel to the fuel pump, and look for a hole at the refill hose connection. once you find it (cuz i'm 90% sure there's one), clean up that area a bit and use either some mighty putty (yeah i know... but it works great! using it on my tank too!) or some make a gasket stuff that resists gas or some "fuel line leak" putty...
oh and just out of curiosity... was that tank full???
M90 Blown M42 :cool:
///M3Mike
« Reply #2 on: May 06, 2009, 08:10:18 AM »
Quote from: B318M42W;71374
It has been doing it at different fuel levels.  This most recent time it was halfway between 1/4 remaining and half.
B318M42W
« Reply #3 on: May 19, 2009, 09:19:00 PM »
bringing an old thread back... an answer to the original title question would be very nice :)
« Reply #4 on: May 19, 2009, 09:29:43 PM »
I have an 86 325is and the tank looks identical to my 91 318i, even has the little hose going from side to side.  However, the pump is different, with a different power connector, the filter mount has an aux pump too, and the plumbing is a little different.  I think it'd fit, if you swapped the pump and some new lines.  Some models had a different tank with a transfer pump too, I'm not sure which ones.
Did you check RealOEM?  The pics there can really be helpful, especially year-to-year.
B318M42W
« Reply #5 on: May 20, 2009, 06:28:58 AM »
yeah tried checking on real OEM, but I don't know why, I couldn't see the part numbers and it said that the parts I was looking for were unavailible/unknown or something...
« Reply #6 on: May 20, 2009, 10:18:56 AM »
I had a few pics but I can't seem to upload them.  I'll try again later.
Ricer Ennemi
« Reply #7 on: April 24, 2010, 05:07:44 PM »
I did it.From '87 325is to '91 318IS.The 318is use 1 single pump
in the tank.Clean the tank and make SURE ur strainer(filter of
the pump)is good.
SpecFC
« Reply #8 on: April 24, 2010, 06:31:57 PM »
325 uses a bigger tank IIRC, they should interchange, but your fuel level sender might be a little off. All tanks have an internal pump, early cars just have both.
RED IS 91
« Reply #9 on: April 25, 2010, 04:13:48 AM »
I bought mine from here ,,,,,,,,,,,,,,,
http://discountgastanks.com/search/
On my first tank of gas and everything is OK so far.
harvey2
any reference info?
« Reply #10 on: July 13, 2010, 12:21:03 AM »
Has anyone seen a writeup or pictures showing the steps to replace the gas tank  in a '91 318is?  I need to swap mine.
\'91 318is
RED IS 91
« Reply #11 on: July 13, 2010, 06:30:24 PM »
I used this write up and I took some photos when I did mine.
http://www.bmwpower.ca/bmw_tech_articles/bmw_e30/e30_bmw_gas_tank_replacement.html
I also replaced my guibo and center bearing while I was there.
Pretty straight forward . Make sure to preload the center bearing when re installing.
Make sure and buy a new connector pipe if it doesn't come with the new tank.
Item #4
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=16_0046&hg=16&fg=05
Good luck
« Last Edit: July 13, 2010, 06:38:17 PM by RED IS 91 »
