Oil leak from oil filter assembly
Author Topic: Oil leak from oil filter assembly  (Read 2580 times)
dlmrun2002
« on: April 11, 2009, 06:31:41 AM »
My 1991 m42 seems to be leaking from the oil filter housing where it bolts up to the block. Any one have this problem? Looks like just a gasket and possible o-ring to fix it. Plus initial looks point to needing to remove alternator mounting bracket to pull off oil housing. Any input?  Mucho gracias.
•••dlm•••
Wizard
« Reply #1 on: April 11, 2009, 07:17:51 AM »
Mine was leaking from the same place. I replaced the gasket and O-ring when I did the the heater plate removal as the top half was mostly disassembled anyway and now no more leaks. Alt bracket will need to be removed...If I recall bracket bolts to the block THROUGH the bracket as pictured on OEM...Not a tough job and no more puddles in the garage...
dlmrun2002
Sounds good
« Reply #2 on: April 11, 2009, 07:55:43 AM »
That  sounds about  right. Funny  I have a new rebuilt  engine and the only leak is form the part I put  back on. I took the oil housing off  to refinish and remember an o-ring and a gasket. What did you use for gasket  sealant?  I think  I might have used hight temp silicone  when I should haved used the stickier  stuff.
DLM
redhead
« Reply #3 on: April 11, 2009, 02:06:23 PM »
Quote from: dlmrun2002;69845
DLM
You shouldn't need any gasket sealant, that could be why it is leaking.
charlesmarseille
« Reply #4 on: April 11, 2009, 02:13:11 PM »
good, i forgot the oring! im getting a ticket for a second ride!
dlmrun2002
« Reply #5 on: April 11, 2009, 03:55:22 PM »
You put your gasket in dry Redhead?  That seems a bit odd/
doug m  ny     nature not culture
