Author Topic: howling noise  (Read 4830 times)
strad
howling noise
« on: April 02, 2009, 11:04:15 AM »
Sounds like it's coming from drivers side rear.  Noise is apparent from about 60 mph through about 75 mph.  Sounds very much like a wheel bearing.  However, sound gets louder if I'm on the gas and softer if I let off (driving in a straight line).  I have not tried the cornering load test to see if it gets louder or softer when loaded/unloaded.  The on/off power bit mentioned above has me a bit mystified because I've not seen a bad wheel bearing behave that way.  What else could it be?
JP 91iS
howling noise
« Reply #1 on: April 02, 2009, 11:50:06 AM »
How is the tire on that side? Could be the differential going out?
-JP
Project M42: generating funds
howling noise
« Reply #2 on: April 02, 2009, 12:47:28 PM »
Sounds like diff ring and pinion noise. The mount is offset to the driver's side, so that might cause the sound location. Try the cornering test; it will narrow things down a lot.
strad
howling noise
« Reply #3 on: April 02, 2009, 01:37:33 PM »
Quote from: JP 91iS;69275
Tire has about 2000 miles on it (all four of them do actually).  It's in good shape.  I was wondering about the diff myself.  I'll try the cornering test next time I get my hands on the car (it's the wife's dd, not mine).
xwill112x
howling noise
« Reply #4 on: April 02, 2009, 01:41:11 PM »
diffrential.
go pick up a used medium cased 4.10LSD out of a autotragic 325i ;)
Ich liebe meinen E30
strad
howling noise
« Reply #5 on: April 02, 2009, 06:41:47 PM »
Is that a direct bolt on?  As in no fooling around with the halfshafts or the driveshaft?
xwill112x
howling noise
« Reply #6 on: April 02, 2009, 07:28:49 PM »
yes sir.
just did it to mine last month myself. fairly easy job.
strad
howling noise
« Reply #7 on: April 04, 2009, 04:58:26 PM »
Update: it does not appear to be wheel bearings, after the cornering load/unload test.  I drained the diff fluid and noted the presence of some metal, very fine particles (after 18k miles in the diff).  Not a terribly large amount, though more than I saw from my 328 after similar mileage.  I'm almost wondering if the (worn out) muffler is giving some sort of resonance between 2700-4000 rpms that I'm not able to hear at lower speeds.  I guess I just keep monitoring, and maybe replace the catback, which I know needs doing.
Is Ansa terrible?  All I'm looking to do is a durable stock replacement.
xwill112x
howling noise
« Reply #8 on: April 05, 2009, 03:44:38 PM »
Quote from: strad;69445
Update:  I drained the diff fluid and noted the presence of some metal, very fine particles (after 18k miles in the diff).  Not a terribly large amount, though more than I saw from my 328 after similar mileage.
holy shit
it should be obvious it's your diff.
strad
howling noise
« Reply #9 on: April 10, 2009, 09:35:24 AM »
Yeah I'll get one.  Gonna take me a few months though -- BMW diffs are not really available at local junkyards.  In the meantime that 410 better hold together lol.
xwill112x
howling noise
« Reply #10 on: April 10, 2009, 10:19:33 AM »
don't yank it around and you'll be ok hopfully.
most of the time, 4-5k clutch dumps or snatching 2nd spinning kills them. ;)
