Author Topic: fuel pump motor swap  (Read 1948 times)
brandon450
« on: March 20, 2009, 03:58:17 AM »
So I have an extra fuel pump from a 89 325i. I know it cant be swapped directly but does anyone know if I can use the fuel pump motor for my m42? :confused:
thanks
« Last Edit: March 20, 2009, 04:04:39 AM by brandon450 »
JP 91iS
« Reply #1 on: March 20, 2009, 11:50:24 AM »
I had a similar issue but the motor I swapped on was from an unknown car.  The guy I bought it from said 91 318 but the assembly was different.  I ended up just swapping it in and trying it out. So far so good.  I picked up a fuel pressure tester so I am going to give it a thorough test to see if the flow rates are the same as stock.
My advice for you would be to just try it out and see what happens.  It's far cheaper than buying a brand new one.  The filter sock didn't fit the same as stock so you will probably need to do some small customizing.
-JP
Project M42: generating funds
