Author Topic: Replaced faulty sensor- CEL turned off but code remains  (Read 2692 times)
ThisIsTheRanger
« on: March 13, 2009, 05:46:24 PM »
I just replaced my AFM with a used one because I was getting code 1224-Intake Air Temp Sensor.  The check engine light went out as soon as I started it up again but when I check for codes with the stomp method, I still get code 1224.  Do I have to reset the computer to get the code to go away?  I tried unplugging all of the injection control fuses for a while to no avail.  I figure the new AFM has a working IAT because the light went out but what's with this code?
JP 91iS
« Reply #1 on: March 13, 2009, 06:30:53 PM »
I remember reading about a way to clear the fault codes stored in the ecu. I don't remember how though. I would try disconnecting the battery for a few minutes.
-JP
Project M42: generating funds
RED IS 91
« Reply #2 on: March 14, 2009, 04:01:20 AM »
Disconnect the Battery for 30 minutes .This should reset the computer.
ThisIsTheRanger
« Reply #3 on: March 15, 2009, 11:07:28 AM »
Thanks guys. That worked. I just didn't want to lose my stereo settings but for some reason they stayed. Now get code 1444 :)
