Solid Flat Top Lifters!
Author Topic: Solid Flat Top Lifters!  (Read 5012 times)
halcrontech
« on: March 09, 2009, 08:47:09 PM »
« Last Edit: March 09, 2009, 08:53:33 PM by halcrontech »
Boyracer
    • http://www.jannousianen.net
« Reply #1 on: March 10, 2009, 02:39:45 AM »
Outside diameter and height seem correct and I think they will fit just fine from that point of view.
Problem is that the stem inside lifter is too short, from lifter top to stem tip about 5 mm if I read correctly. M42 OEM valves require about 14 mm stem height.
Here you can see both short and long stem VW solid lifters:
http://www.rosten-performance.com/pages/solid_lifters.html
The one's at the top are those you want with OEM valves :)
Boyracer
« Reply #2 on: March 10, 2009, 02:41:48 AM »
Also, the Crespo lifters you found are almost 60 grams which is about same as OEM E36 M42 hydraulic lifter without oil. You can convert OEM lifters to solids that weight pretty close to that 60 grams.
Lifters on my link are under 50 grams :)
halcrontech
« Reply #3 on: March 10, 2009, 03:17:13 AM »
Wow Nice. Thanks!! Btw. What modifications must I do to my cams to be used with these lifters? I am using schrick cams. Also do I need to buy the lash caps as well or just the lifters will do?
« Last Edit: March 10, 2009, 03:20:48 AM by halcrontech »
Boyracer
« Reply #4 on: March 10, 2009, 04:57:31 AM »
Shrick cams are meant for hydraulic lifters. Solid lifters require different cam profile. Not sure what will happen if you run solid lifters with hydro cam... But basically to be on the safe side, you should get cam that is meant for solid lifters or get your current cam regrinded for them.
You also need lash caps between lifter stem and valve stem. They need to be grinded to correct thickness by you to allow proper lifter / cam clearance.
romkasponka
« Reply #5 on: March 10, 2009, 05:11:08 AM »
Quote from: Boyracer;68024
What is diferent on cams for solid lifters? My point of view is that solid lifters can handle all cams, but for hydraulic lifters acceleratios and forces could be to high if you take very wide and high lift cams.
« Last Edit: March 10, 2009, 05:17:30 AM by romkasponka »
E30 318is M42
E36 318is M44
Boyracer
« Reply #6 on: March 10, 2009, 05:21:24 AM »
My understanding is that solid cam profiles have profile that first gently takes up the gap (about 0.2 - 0.3 mm when cold) between cam and lifter before cam actually starts to lift. Hydraulic cams start to lift right away. Maybe if there is gap and the lift starts too quickly the cam of lifter surfaces can be damaged?
I am not 100% sure about that, that's what I have read from books. I should have a talk with the cam grinder about this, I bet he knows thing or two :)
romkasponka
« Reply #7 on: March 10, 2009, 05:31:19 AM »
What cams specification you are thinking about? Is it close to 300deg? :)
E30 318is M42
E36 318is M44
Boyracer
« Reply #8 on: March 10, 2009, 05:46:55 AM »
Not yet sure what can be done from OEM cam profile by just grinding... But 280 degrees is about minimum to get the engine breath enough so that there is any sense of revving the engine past 8000 rpm :)
S42 engines has about 312 intake / 304 exhaust cams...
nuvolarossa
« Reply #9 on: March 10, 2009, 07:25:01 AM »
Just to add some specs...
Catcams make camshafts for M42 with 7mm steams and solid lifters:
Here are the specs for the lifter that they use for 7mm valves:
The thing that surprise me is that they do "crazy" cams for the M44 head, they say that solid followers are needed (but they don't sell them...) and 3,95kg/mm single spring needed with the 312°/304° camshaft.
