Head bolts??
Author Topic: Head bolts??  (Read 3706 times)
SW-BIMMER
Head bolts??
« on: March 07, 2009, 11:22:50 AM »
Does any one know the torque pounds of the head bolts??
tumbler
Head bolts??
« Reply #1 on: March 07, 2009, 11:33:05 AM »
Just did this on my '93 318is.
Step 1 - tighten all the head bolts to 22 ft/lbs
Step 2 - tighten them all 90*
Step 3 - tighten an additional 90*
Make sure to tighten them in the correct pattern. Just do a search on here. There is plenty of info.
RED IS 91
Head bolts??
« Reply #2 on: March 07, 2009, 11:34:15 AM »
You have to do a procedure
« Last Edit: March 07, 2009, 11:36:29 AM by RED IS 91 »
SW-BIMMER
Head bolts??
« Reply #3 on: March 07, 2009, 11:49:58 AM »
Thanks!!
I have the book bout i cant find it
RED IS 91
Head bolts??
« Reply #4 on: March 07, 2009, 03:00:44 PM »
Quote from: SW-BIMMER;67859
Thanks!!
You need the E36 manual for the m42 motor.
SW-BIMMER
Head bolts??
« Reply #5 on: March 07, 2009, 04:28:57 PM »
yea that the one i have
Selfish
Head bolts??
« Reply #6 on: March 09, 2009, 09:58:12 PM »
one question on the head removal-note: Did you have to remove the camshafts from their seats? in other words: Can the head bolts be removed (and re-positioned, and torqued) without removing the camshafts?
Also, what´s good at removing all the grime and dust and oil that builds up on these areas (cylinder head, valves, etc)?
I haven´t done this before.
« Last Edit: March 09, 2009, 10:04:10 PM by Selfish »
nomad
Head bolts??
« Reply #7 on: March 09, 2009, 10:59:50 PM »
you can leave the cams in but you need the special Torx socket that reaches down past them to the bolts...
SoCal, 318is: IT RUNS AGAIN!
SW-BIMMER
Head bolts??
« Reply #8 on: March 11, 2009, 02:12:26 PM »
Well i took mine off i just clean them good n i just place some engine assembly lube on them
Selfish
Head bolts??
« Reply #9 on: March 11, 2009, 07:17:38 PM »
yeah, I have that torx socket. I was concerned ´cause I read somewhere online about how hard it is to remove the cams by oneself, and how easily they break on removal if not done properly, making it almost mandatory a 2-person task. I try to read a lot about something that interests me, but also I tend not to believe everything I read, at least not blindly. So, how was your experience on this?
nomad
Head bolts??
« Reply #10 on: March 11, 2009, 09:20:05 PM »
On the M20, I think so, on the M42, no - if you just back each cam bearing nut off 1/4 at a time then you'll be superfine.
