m42 head/m40 block
Author Topic: m42 head/m40 block  (Read 13669 times)
318isteve
m42 head/m40 block
« on: March 05, 2009, 10:55:56 PM »
May be a sill question guys but is there a way to instal a m42 head onto my current m40b18 block?
would the fact that on of these is chain/belt driven cause a problem that couldnt be fixed?
cheers guys in advance
Danny707
m42 head/m40 block
« Reply #1 on: March 05, 2009, 11:10:48 PM »
Isn't the m40 an 8v?
I think it would not work for numerous reasons.
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
m42 head/m40 block
« Reply #2 on: March 06, 2009, 12:32:36 PM »
the blocks are different - cooling lines and oil lines are not the same,
the M40 blick is also narower coz of the 8 v instead of a 16v...
WowMom
BTRA!
Tor Arne Kaasen
m42 head/m40 block
« Reply #3 on: March 06, 2009, 02:25:25 PM »
The m43 raw blok is almost the same.The blok isnt any narower. but front cover  ,under cover for the front ,sump is different etc. and it got difrent typs of oil tubes/squrts under the pistons. and missing 2 oil holes in the midel of the pistons 2 and 3. i guess the m40 loks the same.
i compeard a m42 e30 to a 316m43
BMW E82 120d Coupe and BMW Z3 1,9 m44
318isteve
m42 head/m40 block
« Reply #4 on: March 06, 2009, 11:41:11 PM »
oh ok sweet as thought there would be plenty of write ups on people doing it if posible. But worth asking.
ludiagsm
m42 head/m40 block
« Reply #5 on: March 07, 2009, 03:27:06 AM »
The block m40 and m42 are the same.
  M40 to M42 konversion is possible. Diferense between these two engines thoroughly is in head and front aluminium part(dont know the name in einglish)where is mounted water and oil pumps and driving chain or driving belt .That aluminium part can be mounted with conformity gasket to m40 or m42 block.
 Bearings are the same crank and rods too, pistons are diferent.
I know these info from my own expiriance.
 But these parts and all work to do that  will cost more time and money then  baying used m42 in good condition.
318isteve
m42 head/m40 block
« Reply #6 on: March 07, 2009, 09:22:54 PM »
oh ok makes sense,
and yea thought that might be the case just wanted to see if there was a cheaper option than replacing all the bearings etc in my m42 block i have at the moment.
Ivan Petrov
    • http://www.bmwpower-bg.net/forums
m42 head/m40 block
« Reply #7 on: April 18, 2009, 07:15:01 PM »
Quote from: Tor Arne Kaasen;67819
You can install m42 front covers on m40 block ;)
I`m not sure if m40/m42 has any oil squirts under the pistons, I know that many people choose m44 block rather than m42 becouse of the oil squirts ;)
hesgone2fast
m42 head/m40 block
« Reply #8 on: April 22, 2009, 03:54:02 AM »
Yes it can be done, I´ve done a few already.
Blocks are exactly the same, M40 has oil squirters.
you have to swap everything else from the M42, even the crank.
Right now I have 10,000kms on my M40 engine with M42 block (converted M42 into M40)
