Author Topic: Oil feed for turbo  (Read 3282 times)
walts03
Oil feed for turbo
« on: March 05, 2009, 04:06:32 PM »
Hi i am looking at putting a turbo on my E30 1989 318is. I have read some of the other threads about where to get the oil feed from. but i managed to get  the bolt out that is just bellow the oil filter housing could i use this hole for the oil feed for my turbo?
Danny707
Oil feed for turbo
« Reply #1 on: March 05, 2009, 04:09:26 PM »
I used that, but I guess your not supposed to.
rob_e30
Oil feed for turbo
« Reply #2 on: March 05, 2009, 10:45:58 PM »
I'm sure it will work for that.  Make sure you put a pressure reducer on the oil supply as that is a high pressure fitting.  In fact, we have a part that allows you to use that fitting.  It screws in there and is tapped with a 3/8" NPT female thread.  I'll try and post a pic in or you can PM me your address and I'll send one over.
ludiagsm
Oil feed for turbo
« Reply #3 on: March 06, 2009, 10:55:20 AM »
I did't tried that  but there has dyrti oil ,you must take oil after the oil filter.
« Last Edit: March 07, 2009, 03:32:05 AM by ludiagsm »
