Author Topic: Custom M42 Pistons for my Engine  (Read 12113 times)
halcrontech
« on: January 29, 2009, 08:34:45 AM »
I have been searching around for pistons for build a "MM" style M42 FI motor but could never find it apart from getting it from MM. Gave up and ordered some custom pistons from Wiseco. It has finally arrived.
http://img.photobucket.com/albums/v51/ISS8634/piston2.jpg
http://img.photobucket.com/albums/v51/ISS8634/paper1.jpg
These are the specs of my pistons. They are 86mm bore with a compression of 9:1 and meant for the 88mm diesel crank adn 135mm conrods (I will be getting them from Eagle and they will be stock M50 rods). If you are rebuilding your engine with similar conrods and crank, these piston dimensions may be useful to you.
« Last Edit: January 29, 2009, 08:42:58 AM by halcrontech »
nuvolarossa
« Reply #1 on: January 29, 2009, 10:50:43 AM »
Thank you for the precious data! keep us updated when the engine will be running!
where are you from? price and where you ordered them... I see "wiseco europe" on that paper...
« Last Edit: January 29, 2009, 10:53:41 AM by nuvolarossa »
Tor Arne Kaasen
« Reply #2 on: January 29, 2009, 12:30:17 PM »
Hi. is this for a 1,8 liter ore is it whit a m47 crank? can se the bore of the pistons are 86mm
« Last Edit: January 29, 2009, 12:48:20 PM by Tor Arne Kaasen »
BMW E82 120d Coupe and BMW Z3 1,9 m44
halcrontech
« Reply #3 on: January 29, 2009, 06:49:19 PM »
Quote from: nuvolarossa;65572
Hi! I live in Singapore thus I have to order via their Europe office instead of US one. It cost me 770 Euros so thats around USD993. I emailed Wiseco Europe directly to order the pistons.
halcrontech
« Reply #4 on: January 29, 2009, 06:56:28 PM »
Quote from: Tor Arne Kaasen;65574
No, they aren't stock dimensions. They are 86mm bore pistons intended for use with the M47 crank as well as 135mm conrods (M50 rods).
The compression height is 1.305" which is what you will need to keep the stock 10:1 compression.
I am trying to make a MM copy of the M42 FI engine except my rods are a little longer (134.5mm vs 135mm) and my compression is a little higher (8.6 vs 9). MM motor is not viable for me due to its cost and shipping (shipping from US to Singapore is going to be expensive).
Tor Arne Kaasen
« Reply #5 on: February 01, 2009, 11:08:27 AM »
Can you post som pix of the engine  when the pistons are monted in the blokk pleas:o
Bilding the exsakt same type engine 86mm and the m47 crank whith Garrett gt2860Rs and the ebay obx manifold.
marko
« Reply #6 on: March 11, 2009, 05:56:34 AM »
you do realize that MM's piston set (in a configuration of your choice) is only about $780... + $120 if you want Molly rings.
shipping would have been inexpensive as well...
just my $.02 :)
Quote from: halcrontech;65586
« Last Edit: March 11, 2009, 05:58:35 AM by marko »
DASC/3.45 LSD/Billstein Sport Shocks
BavAuto Lowering Springs/Stromung Exhaust
DS1\'s/X-Brace/Front & Rear H&R Sways
nuvolarossa
« Reply #7 on: March 11, 2009, 06:13:24 AM »
that's a great price from MM, I don't know to Singapore but shipping 770$ of value to europe would mean pay VAT (usually like 20% of insured value) and then other custom taxes... I know as I bought a set of rare Vader seats from Usa and a lot of other things... and shipping will take at least 20days-one month.
marko
« Reply #8 on: March 12, 2009, 08:19:34 AM »
yeah, I forgot about customs...
szed03
« Reply #9 on: March 13, 2009, 08:10:46 AM »
So there's enough material in between cylinders to bore it out to 86mm huh?  It's likely pushing it though.  I'd love to see pics of the block.
rob_e30
« Reply #10 on: March 13, 2009, 09:03:59 AM »
The M42 has the same bore pitch as the M/S50 engines.  Some of those guys go bigger but I would not go too big on the cylinder diameter for FI.  High compression NA I think goes to 87.5mm.
marko
« Reply #11 on: March 14, 2009, 12:32:01 PM »
Quote from: szed03;68218
here ya go... its metric's M44 2.0L I just bought.
more here...
http://www.318ti.org/forum/showthread.php?t=25646
« Last Edit: March 14, 2009, 12:34:15 PM by marko »
szed03
« Reply #12 on: March 14, 2009, 09:27:28 PM »
Awesome!  Thank you mucho rob and marko! :D  Time for me to get a spare M44...and space to store it. :p  LOL
dsm2002
« Reply #13 on: March 15, 2009, 12:52:15 AM »
Quote from: marko;68290
more here...
Sorrry if this is otherwise obvious, but what diameter are those pistons?
marko
« Reply #14 on: March 16, 2009, 07:39:47 AM »
not even obvious to me & I own the damn thing.. LOL :)
they are 87mm...
Quote from: dsm2002;68321
