Author Topic: another budget turbo build...bottom mount  (Read 90258 times)
nickmpower
dynotech motorsports budget turbo build
« Reply #135 on: December 01, 2009, 01:59:02 AM »
i'd be interested in a kit
ponchiz318
« Reply #136 on: December 05, 2009, 03:03:54 PM »
Quote from: Blip Bavarian;79800
which vac turbo kit are you talking about?  I looked on their site and didnt find anything.  Do you have a link?  I love the idea of turboing my m42, but dont have the time or knowledge to piece together a custom kit...
http://store.nexternal.com/shared/StoreFront/default.asp?CS=vacmotors&StoreType=BtoC&Count1=740062892&Count2=657203316
Quote from: VAC Motorsports
Kit Includes:
CP Forged BMW Turbo Piston Kit, includes rings, pins, and locks (8.5:1)
(4) Forged Arrow Precision H-Beam Connecting Rods with ARP Hardware
VAC Multi-Layered Steel Head Gasket (.070)
ARP Head Stud Kit
The kit costs $2300. I can't do this project until I get another job. Hopefully by then, the OP offers bolt on turbo kits or parts :D
kevins08
« Reply #137 on: December 07, 2009, 04:25:55 AM »
Quote from: ponchiz318;82536
no need for this kit for anything under 10psi. thats for the big boys, and even then you're better off buying the parts you need individually.
ChItalian1027
« Reply #138 on: December 19, 2009, 01:26:04 AM »
hey todd, hows the build coming along so far?? i might turbo my M42 ti as soon as i get out of college or maybe get a job, but it looks like its coming along nicely.
Greg
'95 318ti
'04 Mini Cooper S
BMACD
« Reply #139 on: January 03, 2010, 08:08:40 PM »
Question for Todd can the OBX headers be turned upside down and work in a top mount setup with a little modifaction of course cheers Billy
kevins08
« Reply #140 on: January 04, 2010, 10:07:50 PM »
that will put the turbo in a really wierd spot.....probably not recommended :)
tglaze
    • http://www.dynotechonline.com
« Reply #141 on: January 09, 2010, 10:44:34 AM »
Quote from: kickass95318ti;83236
still havnt touched it.  really miss my car though.  have been brainstorming on the manifold and have something figured out, just need to do it.  we are constantly in the middle of like 10 large projects so its hard to justify any extra time to work on my own car when there are paying customers in line.  getting close though. stay tuned guys.
Todd Glazier
call 760-726-7111 for parts
tglaze
« Reply #142 on: January 09, 2010, 10:46:13 AM »
Quote from: BMACD;83998
not really, the turbo flange hits the head.  you woulf have to slice the flange and rotate and angle it and weld it back together.  sucha nice manifold for the $$.  would highly recommend for any e36 user.
Todd Glazier
ponchiz318
« Reply #143 on: January 19, 2010, 09:49:48 PM »
Quote from: kevins08;82593
I'm a big boy now. Look, no stains!!:p
Seriously though, once I jump on a turbo build, I'll be shooting for more than 10psi. Make a worthwhile build and do it right from the start. But that's just me though.
Awgy
« Reply #144 on: January 25, 2010, 12:53:49 PM »
Quote from: tglaze;65177
I build the megasquirts here..
heres another item on the car i forgot to mention.  we do the m20 lightenbed flywheels and swap the ring gears so they are PnP for m42 as well. threw this in with a stage 3 m20 clutch.
might tack on a few extra bucks to the build for this setup as well.
I sent you a PM a couple weeks ago asking how much this flywheel is but no response.
I figure this will be a better way to find out.
So how much for just the flywheel?:)
longms
« Reply #145 on: January 26, 2010, 09:08:30 PM »
Quote from: Awgy;85603
flywheel is $250
stock m20 clutch kit is $195
upgraded clutch options go up from there
flywheels are also 12lbs for the m42 application
Figured I would save him the time and post this up. He posted it up in the middle of the thread. I only know this cause I just read the entire thing. The flywheel works with the M42 starter and requires an M20 clutch. Not sure about T-Bearing though.
Hope this helps
Awgy
« Reply #146 on: January 27, 2010, 12:15:12 AM »
Quote from: longms;85749
flywheel is $250
Hope this helps
Thanks,
I read the entire thread when I was building my setup. I thought I saw a price once but couldn't find it again to confirm it.
Gray S.
« Reply #147 on: January 27, 2010, 11:38:24 AM »
Quote from: Awgy;85766
Thanks,
I wonder if that setup is completely plug and play though?  I am in need of a clutch fairly soon, but I've read so many conflicting reports about what the m20 kit needs.  Longer flywheel bolts, some sort of spacer etc. etc.  If that kit is plug and play completely it would really spike my interest.
e30guydownunder
« Reply #148 on: January 27, 2010, 07:39:35 PM »
You need shorter flywheel bolts (the single mass M20 ones), and the spacer you need comes on the flywheel, you just have to put it between the flywheel and crank instead of the bolt heads and the flywheel.
I used the M20 TO bearing that came with my clutch kit, no issues what so ever.
longms
« Reply #149 on: January 27, 2010, 09:10:38 PM »
tglaze...Have you put anymore thought into offering a turbo kit like the one you are building? What are you overall horsepower goals for this project?
