Author Topic: another budget turbo build...bottom mount  (Read 90264 times)
e30nub
dynotech motorsports budget turbo build
« Reply #105 on: June 01, 2009, 01:53:32 AM »
Updates?!?!
-Pierre
1991 318is
1988 325is
1991 318i (sold)
Blip Bavarian
« Reply #106 on: June 09, 2009, 04:52:43 PM »
bump
ApocolypseAutoEngineering
« Reply #107 on: June 22, 2009, 11:15:09 PM »
bump
E30 FOR LIFE!!!!
tglaze
    • http://www.dynotechonline.com
« Reply #108 on: June 27, 2009, 01:36:59 PM »
ya, sorry.  i fail.
i havnt touched the car since like feb or march.  im expanding the shop and things are crazy right now.  i will be pulling the motor to build a more efficient manifold as soon as i get a chance and project will go on.  i promise.
car just came up for smog too so after i pull the motor i will probably put in a stock one and get it through smog first too.
Todd Glazier
call 760-726-7111 for parts
Bunta
« Reply #109 on: July 23, 2009, 09:03:41 PM »
Im interested to see someone try a .140 MLS gasket.
6 cylinder e36 people love them and are making 450whp at 16psi out of a 3.0
I quess leaking around the profile gasket is a problem in an m42 as prevoiusly stated. But that could be remedied
http://forums.bimmerforums.com/forum/showthread.php?t=1218177
http://forums.bimmerforums.com/forum/showthread.php?t=1217829
Heres a guy on BFC. Obviously its hard on the motor running such high boost but I wonder what size gasket hes using?
Im thinking of a .140 one for my car just to try it. There not too expensive, it'd be a pain to have to change the gasket again though.
Someone needs to do more testing with one.  You can get 9.1:1 with just a gasket and the bottom end is pretty strong.
I plan on running VEMS EMS, Holset HX35 turbo, .140 HG and APR Studs.
Id like to get around 15psi. 300ish Whp
Hunter
bwawuz02
« Reply #110 on: July 28, 2009, 07:41:47 AM »
todd,
is MS running fuel, spark, and boost? could you setup a MSPnP for me to also incorporate a knock sensor? MAP sensor?
Danny707
« Reply #111 on: July 29, 2009, 03:50:46 AM »
Quote from: bwawuz02;75957
todd,
MS is run on a MAP sensor, you delete your AFM completely. MS handles fuel and spark. Boost is handled by your wastegate, unless you have some sort of electronic boost controller, yada yada.
bwawuz02
« Reply #112 on: July 29, 2009, 07:09:11 AM »
Quote from: Danny707;75990
Not my first turbo rodeo, but thanks for your input. former WRX owner here. it just appeared in the pictures that he was running a manual boost controller, but i read matt325is write-up on using the typhoon controller, not sure if he was capable of putting that in a MSPnP for me. It's also a little vague in his posts to whether he's running a knock sensor or not. Here's a spy-tip for you, i joined this forum before you, but only have 10 posts; I read a lot.
After further reading, i found the MAP Daddy 4bar setup on diyautotune.com
I'm curious to know if that location on the oil pan ended up working for the return line? You've got a very impressive setup todd, i'm in NorCal and would love to come by the shop someday.
« Last Edit: July 29, 2009, 07:14:02 AM by bwawuz02 »
Danny707
« Reply #113 on: July 29, 2009, 03:08:54 PM »
Quote from: bwawuz02;75991
I wasn't trying to be sarcastic in my last post, just fyi.
But Todd's shop is actually way down south.
bwawuz02
« Reply #114 on: July 30, 2009, 10:42:26 AM »
Quote from: Danny707;76015
okay kid, you're officially on quiet time!
I know where his shop is okay, he didn't mention it being in cali; i found it on the Contact Us tab of the dynotech web page and google mapped it. Just like i know you're in Vacaville, maybe i'll come see you someday; i'm stationed at Travis AFB.
« Last Edit: July 30, 2009, 10:45:28 AM by bwawuz02 »
Awgy
« Reply #115 on: July 30, 2009, 01:22:31 PM »
I think someone needs a nap.;)
Danny707
« Reply #116 on: July 30, 2009, 03:40:38 PM »
Fantastic!
I would enjoy meeting another enthusiast.
bwawuz02
« Reply #117 on: July 31, 2009, 10:01:55 AM »
Quote from: Awgy;76069
yeah, base exercises SUCK!
RouteZeroDesign
« Reply #118 on: August 04, 2009, 04:31:58 PM »
Very impressed with the build Todd.
Your Ms is making me reconsider my plans for a rrfp.
Looking forward to the update ;)
E30PQ
« Reply #119 on: August 06, 2009, 02:35:25 AM »
Quote from: Bunta;75781
Hunter
We run an E30 Turbo M42 in BMW club racing.  Those layered metal head gaskets aren't that great.  They look good but in our experience they didn't work as well as the stock head gaskets.  We run the stock M44 head gasket.  As I'm sure you know, turbo motors give you the opportunity to learn a lot about head gaskets.  IMHO I would go with the stock gasket and save that extra money for a spare stock head gasket.
Regarding this build thread, it would be interesting to see some dyno results.  We used a Dyno Dynamics which is a steady state dyno and allows tuning with partial throttle.  What ECU are you running?
