If I start it when the motor is cold, everything is fine. But when I start after the motor has been run, even if its just for a minute, its spits and sputters with the revs jumping between 300 and maybe 1200 requiring you stay on the gas to keep it from dying out. If I start it and try to take off while its doing this, it will have like 3 horsepower and then once it passes 2,000 RPM be just fine. No matter what you do, the problem lasts about 1 minute and goes completely away. Is this some problem with a cold start valve or something like that? Thanks
