Author Topic: Rough idle/stalls when started warm?!?!?!  (Read 3891 times)
91e30181
« on: January 17, 2009, 09:39:28 AM »
If I start it when the motor is cold, everything is fine. But when I start after the motor has been run, even if its just for a minute, its spits and sputters with the revs jumping between 300 and maybe 1200 requiring you stay on the gas to keep it from dying out. If I start it and try to take off while its doing this, it will have like 3 horsepower and then once it passes 2,000 RPM be just fine. No matter what you do, the problem lasts about 1 minute and goes completely away. Is this some problem with a cold start valve or something like that? Thanks
xwill112x
« Reply #1 on: January 17, 2009, 09:43:04 AM »
sounds like a huge vaccum leak/icv to me...
try cleaning your icv and replacing all your cracked hoses.
that should fix your problem...if not get back with us.
Ich liebe meinen E30
91e30181
« Reply #2 on: January 17, 2009, 09:46:03 AM »
I just bought this one a month ago, and its spent that whole time getting paint. Now thats done I wanna look further into this. Im gonna tear it down hopefully next weekend. Hoses are pretty new and I dont hear any vac leaks. Whats the icv?
xwill112x
« Reply #3 on: January 17, 2009, 09:52:20 AM »
idle control valve.
you could just buy a new one, but there like 168$$ new. so if your anything like me, id rather try cleaning/fixing it first. ;)
but the intake manifold hides manyhoses and lines...i'd just visually inspect all the hoses i could, and if they look new...maybe it's just your icv
91e30181
« Reply #4 on: January 17, 2009, 10:13:53 AM »
Yeah my other e30 I had to replace all the hoses, so Im familiar with the process. Idle control valve...gotcha...its the morning so Im not all there just yet. Its been cleaned so I guess replacement is the next step, and $168 isnt so bad really, just as long as it works!
xwill112x
« Reply #5 on: January 17, 2009, 10:32:15 AM »
try cleaning it with electrical cleaner?
if it works...
then you can give me the 168$$ ;)
91e30181
« Reply #6 on: January 17, 2009, 03:42:31 PM »
Oooh tried that, so no $$$ for you....but thanks for the help!
xwill112x
« Reply #7 on: January 17, 2009, 06:51:55 PM »
hmmmm....make sure all hoses are secure?
Burnall4
« Reply #8 on: January 21, 2009, 01:12:54 PM »
welcome to the club...search my massive thread and you will see all that suffer. Some people have figured out their problems, some haven't. I am just looking for the definitive answer.
Can you accelerate when it starts doing the rough idle, because I can't.
Current BMW: Looking
Current Truck: 06 Chevy 1500 4x4 Crew Cab
Current Motorcycle: 2005 CBR 600rr (race bike)
1991 318is sold
1990 325is sold
AcSchnitzer318is
« Reply #9 on: January 21, 2009, 09:33:20 PM »
^What he said.  Lot's of ppl been working on this for awhile.  I'm betting the ICV and new hoses don't fix your problem if you can't hear a vacuum leak and have already tried cleaning the ICV.
I was hoping that fuse box thing would turn out to be the answer... haven't heard anything about it since.
roundel318
« Reply #10 on: January 24, 2009, 09:50:50 AM »
When you start it up warm, how does it do at WOT? (Wide Open Throttle)
I ask because O2 readings are tossed at WOT......
