Author Topic: It's Cold, It's Winter, How Long Does your M42 take to Warm Up?  (Read 4043 times)
batsbats
« on: January 16, 2009, 02:52:00 PM »
My first winter with the car.
I usually let it warm up for 1-2 minutes each day before driving off.  Shifting around 2.5-3k, it takes about 5-6 minutes after driving off.  So about 6-8minutes each winter day.  It's about 25-35 degrees this month.
I believe I have a bad tstat though.
What about you guys?  State the ambient temps too!
« Reply #1 on: January 16, 2009, 06:04:00 PM »
Forever and a day. Remove the clutch fan in the winter. It helps.
Meister
« Reply #2 on: January 18, 2009, 11:23:31 AM »
During winter mine takes about 3-4 minutes driving after 1min warm up.  During spring/summer usually about 3-4min driving.
sennasixty8
« Reply #3 on: January 20, 2009, 10:05:51 PM »
Quote from: tjts1;64832
how exactly did you do this?  I've got a stuck tstat, and norcal winters aren't that cold lately...   I'm only 1.2 miles fr the freeway, and a 10 mile commute at fwy speeds equals 1/8th on the temp gauge.
xwill112x
« Reply #4 on: January 20, 2009, 10:22:50 PM »
allen wrench on the fan. i think theres 4 allen bolts..?
there on the front of the fan, easy 3 min job...just remove the shroud first
Ich liebe meinen E30
twright
« Reply #5 on: January 21, 2009, 07:13:22 AM »
Taking off the bolts to the fan is too hard.  I just took off the big nut (1.25"?) that holds on the whole fan assembly.
« Reply #6 on: January 21, 2009, 09:54:31 AM »
Quote from: sennasixty8;65076
Just remember the threads are backwards. So righty loosy, lefty tighty. A sqirt of liquid wrench or even WD40 on the thread helps a lot.
xwill112x
« Reply #7 on: January 21, 2009, 11:54:04 AM »
i thought removing bolts was easier....
ohwell...everyone is to there own opinion..
« Reply #8 on: February 01, 2009, 08:14:00 AM »
Electric fan FTW :). Mine, with the electric fan, takes almost 20 minutes. The fan never comes on in the winter. This is to get to normal summertime operating temps though.
carlos318is
« Reply #9 on: February 02, 2009, 10:17:48 AM »
Mine takes about 3miles or 4-5 mins
roundel318
« Reply #10 on: February 04, 2009, 02:46:43 PM »
I can get my stat well into the blue after 10 min of idle at ~20 degrees F.
///M3
« Reply #11 on: February 24, 2009, 01:29:21 PM »
My car takes roughly 8 minutes or so, but the outside temp is around 10 degrees.
Voluted
« Reply #12 on: February 24, 2009, 03:05:01 PM »
15-20 minutes in -25C which is around -13F
