Author Topic: M42 with M47 Crank  (Read 4482 times)
walts03
M42 with M47 Crank
« on: January 16, 2009, 06:26:11 AM »
Hi i am a newbie to this site.
i am in the uk and i have just got hold of a M47 Crank :D
I know what you can do with
M44 pistons (2.0l) and
S50 pistons (2.1l) but what displacement and compression ratio would the engine be with the standard m42 pistons and an m47 crank?
Thanks
rob_e30
M42 with M47 Crank
« Reply #1 on: January 16, 2009, 08:37:19 AM »
84mm pistons with an 88mm stroke is 1.95L
walts03
M42 with M47 Crank
« Reply #2 on: January 16, 2009, 10:06:38 AM »
Cool would i need new engine management system tho?
rob_e30
M42 with M47 Crank
« Reply #3 on: January 16, 2009, 05:32:08 PM »
I can't imagine that you would.
crazzy_hippo
M42 with M47 Crank
« Reply #4 on: January 16, 2009, 08:53:02 PM »
Btw, take note that you will need to modify the crank (shorten the nose a little and additional notch for the woodruff key).
Also, you will have to deck the pistons.
walts03
M42 with M47 Crank
« Reply #5 on: January 17, 2009, 04:07:26 AM »
yeah will get the crank done and the deck height done. should be cool. thanks guys
