My engine was previously rebuilt back in the beginning of 2008 (Jan-Mar time frame). All of the parts used were all brand new parts.
The one part I am now having an issue w/ is the black plastic coolant "pipe" that is inserted into the driver's side of the engine block. The part is pictured below, the photo source of this part is courtesy of bimmerparts.com:
When on the REALOEM website, the part is referred to as the "connector", BMW part # 11531714738 ($14.17 per REALOEM). The O-ring for this part is listed as BMW part # 11531709157 ($2.28 per REALOEM).
The connector pipe on my M42 is seeping at the main flange where it is inserted into the engine block. My M42 also has had the complete "mess under the intake" deletion when the engine was rebuilt, so I have very few hoses remaining, I've checked all other possible areas of where coolant can leak and all of those areas are completely dry. The coolant is seeping past the flange and puddles onto the engine block right below the connector pipe.
I'm not sure if the replacement O-ring for this part has failed or if this part is just a bad aftermarket reproduction part. I'm thinking it may be made by a company called "URO", as where the part was originally purchased, that vendor only lists a "URO" coolant connector pipe.
Has anyone experienced a new part failure, specifically this coolant connector pipe and if so, what was the brand or who was the part manufactured by?
My current thinking is that the part is made w/ inferior plastics and the plastic flange & tubing where it meets & goes into the engine block has warped due to heat off the engine block, causing coolant to seep past the O-ring and flange... This could be BAD if an unsuspecting M42 owner does not take notice to any coolant seepage in this area, as it is kind of hidden by the intake, other hoses & the oil can. If you have replaced this part recently, I would certainly check that area of the block and look for any coolant stains or small puddling under the pipe.
Looks like I may be replacing this part w/ an original BMW connector & O-ring from the local BMW Dealer.
