Author Topic: temp gauge not working...now heat isnt working well??  (Read 5558 times)
xwill112x
« on: December 19, 2008, 09:32:16 AM »
so my temp guage crept up from the blue as normal...but as i was driving it went back down...and wont come up? it ust stays in the middle of the blue column.
and now this morning i noticed that the heat doesn't work that well but the fan is blowing fine?
this is really confusing me..any input would be appreciated
:confused::confused::confused:
Ich liebe meinen E30
txleadfoot
    • Google Profile
« Reply #1 on: December 19, 2008, 10:08:47 AM »
I wonder if your thermostat is stuck open.
B318M42W
« Reply #2 on: December 19, 2008, 05:06:13 PM »
+1 on the thermostat idea
M90 Blown M42 :cool:
batsbats
« Reply #3 on: December 19, 2008, 08:26:35 PM »
Check your coolant tubes from the radiator to the block. (After you've driven for a bit, or let it 'warm up')
-Are they cold or warm?
The t-stat might be stuck open as suggested.
Jimmy Lewis
« Reply #4 on: December 19, 2008, 08:29:07 PM »
Quote from: xwill112x;63194
Feel lucky that it decided to fail in the open position. Sounds like a good time to flush your coolant and replace that thermostat. Sucks its really not a garage gig being so cold outside. Good luck.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
Deftones
« Reply #5 on: December 20, 2008, 11:26:38 AM »
when the gauge returns to blue, open the hood and put an hand on the engine, if you resist for less than 1 second your engine is hot and the gauge is gone, if you can keep your hand for a lot more time you must change your thermostat
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
roundel318
« Reply #6 on: December 20, 2008, 12:58:38 PM »
+2 or whatever on the stat.
xwill112x
« Reply #7 on: December 20, 2008, 11:28:00 PM »
k. thanks for all your help guys!
Cobra Jet
« Reply #8 on: January 08, 2009, 10:40:49 AM »
There is also a heater control valve that comes off the driver's side of the heater core.  The heater core is tucked behind the center console under the dash.  You have to remove the center console & center console shifter section to see or even access the heater core & that valve.  When the valve starts to fail, it does not allow the proper flow of hot coolant through the heater core, thus you end up with less & less warm air in the cabin...
From what I have seen online, these heater control valves are NOT cheap by any means, upwards of $100+ to replace just that part.  While you're in there replacing the valve, might as well replace the heater core too, since heater cores do not last forever...
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
xwill112x
« Reply #9 on: January 08, 2009, 04:36:16 PM »
jusr replaced the heater core in feb 08
xwill112x
« Reply #10 on: January 08, 2009, 04:38:37 PM »
plus i dont think it would be that, bc the gauge reads cold.
i have a thermostat, jus came in 2 days ago, but havent replaced it yet, due to the fact my alternator died after changing the voltage regulator.
i'll let you know how it goes.
keflaman
  • -Receive: 35
« Reply #11 on: January 11, 2009, 01:37:58 AM »
Quote from: xwill112x;64343
Not necessarily. My gauge barely gets out of the blue, but when I put my scanner on the car and read my data the temp was 193*F.
I'm going to replace my SI board battery and see if that helps.
xwill112x
« Reply #12 on: January 11, 2009, 12:03:08 PM »
oh, well i just think the probability of both parts breaking at the same time isn't as realistic as the thermostat going bad on a car wih 166k.
but we'll see how things go when i get the time to fix the thermostat.
studying for finals takes to much time!!
xwill112x
« Reply #13 on: January 13, 2009, 02:56:21 PM »
not to revive a dead thread or anythinhg buttt....
is there a gasket for the thermostat houseing plate thing i have to buy aswell...bc i have enough time today to replace my thermostat, but im not sure if i need another gasket?
doitover
« Reply #14 on: January 13, 2009, 04:00:20 PM »
Yes, there is an o ring that should come with the thermostat and a paper gasket for the thermostat housing. Probably not a bad idea to have an m6 helacoil kit with you as well.
Quote from: xwill112x;64595
