rebuild potential
Author Topic: rebuild potential  (Read 3317 times)
fast_eddie
rebuild potential
« on: December 11, 2008, 10:46:11 AM »
Im planning on rebuilding my m42 with 160g on it. Im thinking that if im gonna tear it down might as well give it some goodies. What I think I might want to do is.
Get hardened sleeves…. who if any make them/they are removeable right?
Hi pro pistons w/Teflon cote round and ceramic top coat.
Definitely rod bearings maby rods if I can find any good ones and keep my arm.
Balance/blueprint
Ceramic coat head
Whats the best for valves and springs? Rocker updates?
Ive seen a couple cams, what do I look for?
Solid lifters
Ive already got lsd but not sure what one, do u know?
Then intake, any good sudgestions?
What do u think would be the best ecu?
Maby put a turbo on at same time, maby after if it costs too much.
How much pressure can I run one of these at and still be driveable?
xwill112x
rebuild potential
« Reply #1 on: December 11, 2008, 12:03:44 PM »
you can run a turbo with 7-9 psi easily on stock internals. as for drivable, depends on how much $$$ you have. and as for price, it shouldnt be more than 1300-1600$ to run a turbo setup, espeacially if your a diy-er.
Ich liebe meinen E30
fast_eddie
rebuild potential
« Reply #2 on: December 11, 2008, 01:31:43 PM »
does it cost a lot to make an engine driveable and have great top end?
xwill112x
rebuild potential
« Reply #3 on: December 11, 2008, 03:04:52 PM »
top end as head and valves, or top end as in high speed?
fast_eddie
rebuild potential
« Reply #4 on: December 12, 2008, 07:35:43 AM »
as in be able to build an engine that preformes on the road as well as the track, hi end=hi rpms. i want it to be my daily driver still after i mod it, is there any driveability issue with these engines after you soup em up? im looking to end up with around 225hp.
roundel318
rebuild potential
« Reply #5 on: December 12, 2008, 08:17:38 AM »
Quote from: fast_eddie;62678
sounds kinda lofty with stock internals and keeping it reliable.......
xwill112x
rebuild potential
« Reply #6 on: December 12, 2008, 11:18:59 AM »
boost it.
get a set of pistons, valve springs, and a turbo setup with a tune, you'll have all the power, and top end you'll ever need
fast_eddie
rebuild potential
« Reply #7 on: December 16, 2008, 07:52:05 AM »
im not really planning to ues the stock internals. im going to completely rebuild it from crank bearings to throttle body. might as well go all out when i do it, its still in the planning stage. i think i saw something about m3 injectors being a good upgrade on the m42. true? definately going to need bigger injectors.
xwill112x
rebuild potential
« Reply #8 on: December 16, 2008, 10:57:27 AM »
ive never heard of it...
go with 4 pintle mustang injectors or a mega squirt setup.
