Author Topic: Bigger Injectors Stock Tune Info  (Read 3274 times)
bearsbmw
« on: November 27, 2008, 01:00:52 AM »
I would like to note all of the FI folks injector upgrades and engine behaviors after startup on stock tune befor the power tune
Injector Brand(curious)=
Injector #rating=
Engine Behavior =
Post away thanks!
« Last Edit: November 27, 2008, 01:06:48 AM by bearsbmw »
roundel318
« Reply #1 on: December 17, 2008, 01:39:05 PM »
Quote from: hongri1998;63018
ball valve featuring with uni-body, top entry trunnion mounted ball. This type of valves gives convenient of in-line repair or replace valve internal components without dismantling it from pipeline. series ball valve is all fire safe designed comply with API 607 & API 6FA.
ball valve spam?
have we really gone this low?
Awgy
« Reply #2 on: March 22, 2009, 10:05:01 PM »
Today I just installed some Saab injectors from the junkyard. They are out of a 91 Saab 900 turbo.
Brand: Bosch
Part #: 0280 150 761
LBS/HR: 22
cc/min: 238.1
I installed these cause my factory injectors were leaking. When first installed my car had a little hesitation when given some throttle. After car warmed up the hesitation was gone. I took it on a 3 hour cruise through some twisties. The performace was great. The car starts right up and the response is perfect. I have not tested on a cold startup. I will tomarrow morning before it gets warm out. In the next month I will have a PLX wideband monitoring the system. I will post back with the cold start up results.
Awgy
« Reply #3 on: March 23, 2009, 03:21:54 PM »
Well... there was no hesitation at all. The car has a better response than befor. These injectors are single pintle design.
