Author Topic: bad idle...icv?  (Read 3556 times)
xwill112x
bad idle...icv?
« on: November 25, 2008, 12:13:57 PM »
ok so... here it goes..
my e30 has been messing up over the course of one month and its really pissing me off. it's been idling rough aka 600 to 1700 rpms with both tb's closed so that rules out throttle linkage. it will only idle shitty after its been driven...not when first cranked in the morning. sometimes when i come to a stop and push the clutch in , it will die all together. but then smetimes idle at 1600 rpms. <<--really annoying cause when u barely touch gas it will rocket off in an unexpected way.
pelican parts is like $$162.00 for an ICV...
would these symptoms be an icv...and could i fix the current one before i spend that much on one?
Ich liebe meinen E30
bearsbmw
bad idle...icv?
« Reply #1 on: November 25, 2008, 12:17:39 PM »
take ICV out and put 12 volt's to it and see if it opens quicky and smoothly ... if it's slow(clean) or won't open then replace
take a peice of electrical tape and jam it between the two prongs or get 2 small butt connectors befor you atemp test to keep from arching
« Last Edit: November 25, 2008, 12:19:59 PM by bearsbmw »
///m42 sport
bad idle...icv?
« Reply #2 on: November 25, 2008, 09:56:37 PM »
Also might want to check the voltage regulator on your alternator.  I just replaced my whole alternator and noticed a immediate improvement in the idle.  before it would hover at 900-1100 at idle.  Now its dead at 900 at idle.  I found this out incidentally when my voltage regulator crapped out on me and I was left stranded on the road.  Its easy to check.  Remove your airbox, and check the back of your alt.  Its held in by two philips head screws.
xwill112x
bad idle...icv?
« Reply #3 on: November 26, 2008, 11:39:08 AM »
i read somewhere on here that they could be revived with electrical cleaner? is that true? b/c the price on a new one is a LITTLE steep (168$$) <<---fts
bearsbmw
bad idle...icv?
« Reply #4 on: November 26, 2008, 12:05:29 PM »
Quote from: xwill112x;61736
I took a dremil tool polishing wheel and wd-40ed the shit out of it and it looked like new inside after I sprayed throtle body cleaner in it... it's a sealed unit so fire away with the WD-40 and whatever else within reason... While your at it use the dremil tool wirebrush on the butterfly valves and spray with cleaner after
« Last Edit: November 26, 2008, 12:08:21 PM by bearsbmw »
roundel318
bad idle...icv?
« Reply #5 on: November 26, 2008, 01:22:22 PM »
Agreed, clean the ICV and perform the test! :)
xwill112x
bad idle...icv?
« Reply #6 on: November 26, 2008, 06:58:06 PM »
k ill let you all know how it goes.
