Author Topic: Injector Duty Cycle & AFM questions  (Read 7280 times)
bearsbmw
« on: November 24, 2008, 12:43:42 AM »
Im sure AFM Controls Injector duty cycles so then a fully open AFM door flap would be 100% duty cycle ?
Does the O2 sensor signal also have influence over duty cycle when  in WOT
The reason I ask is I have a very intresting idea im going to try with a 02 simulator, bigger injectors, and some afm door figeting and my 12psi of boost and my crude tune
« Last Edit: November 24, 2008, 03:11:09 AM by bearsbmw »
roundel318
« Reply #1 on: November 25, 2008, 02:08:43 PM »
I believe O2 readings are tossed at WOT.
bearsbmw
« Reply #2 on: November 25, 2008, 07:18:03 PM »
Quote from: roundel318;61674
Ahhh yes stupid me ... back to the drawing boards
Cristian G in Oz
« Reply #3 on: November 25, 2008, 07:21:07 PM »
Also injector duty cycles are usually indexed with TPS and engine speed as well.
1990 318is
bearsbmw
« Reply #4 on: November 25, 2008, 07:25:36 PM »
so I would need to find a stock fuel map to actulay know 100% correct?
bearsbmw
« Reply #5 on: November 25, 2008, 07:29:28 PM »
anybody know where I could find a map?
roundel318
« Reply #6 on: November 25, 2008, 09:41:39 PM »
I remember reading somewhere that WOT was like 105 or 110%?
bearsbmw
« Reply #7 on: November 25, 2008, 10:02:15 PM »
Quote from: roundel318;61698
Sweet! some insurance would be nice and it would realy help with my injector selection
Cristian G in Oz
« Reply #8 on: November 26, 2008, 05:59:03 AM »
I'm not so sure about this.  If your talking about duration of opening it is impossible to have more than 100%:confused:.  Even 100% open is very bad as your injector never closes:(.
I know for MoTec they recommend no more than 80% IJPU.  Over that the injector gets inefficient and can cause more problems than it's worth.
I know when we had IJPU on the E30 M3 that was at 82%-83% across 4 cyl's we got some weird readings from the ECU.
When we changed to bigger injectors problems went away.
1990 318is
« Reply #9 on: November 26, 2008, 08:55:25 AM »
Over about 80% duty cycle, injectors start to lose accuracy. At 100% the injector essentially stays open continuously and can be damaged.
roundel318
« Reply #10 on: November 26, 2008, 01:17:03 PM »
Perhaps I am confusing this figure for something else, I anticipate the actual figure :)
bearsbmw
« Reply #11 on: November 26, 2008, 07:36:00 PM »
Quote from: roundel318;61744
it's killing me haha
roundel318
confused figure
« Reply #12 on: November 27, 2008, 02:36:40 PM »
I think I was confusing the 105/110% number for the TPS figure at WOT, not injector duty cycle, now that I think about it :)
bearsbmw
« Reply #13 on: November 27, 2008, 03:03:27 PM »
I might be on to something so fantastic and cheap you will all be looking for a AFM driven car forever :P will keep updating
« Reply #14 on: November 28, 2008, 11:49:59 PM »
The injector duty cycles are controlled by (in no particular order):
AFM (primarily)
Intake Air Temp.
Coolant Temperature (warm-up enrichments)
Throttle Position
Exhaust Gas Oxygen Content*
*The O2 sensor's input is only used below 85% throttle & 4000RPM, if I recall correctly.
Keep in mind that the AFM's signal is the load-variable's primary input, and that ignition timing is directly affected by the ECU's computed load value at a given instant.  Tweaking it might cost you some performance due to incorrect ignition timing, or a whole motor.
What exactly are you working on here?  I saw evidence of boost......
