I need to find a away to simulate the electrical fluctuation of a normal cycle o2 sensor and keeping the ECU happy ... Not sure how this will be done yet but will take any suggestions ... thanks!
I'm trying to do that with the analog output from my wideband (innovate lc-1), but until now I get only ground issues and the value that ecu see goes negative, thus ecu show the error about the wrong voltage...
you need to trick the heater system of the lambda sonde otherwise it will show the error for that too.
there are some circuits that plug directly on the lambda connector, search with google for "o2 simulators"... be careful, not all simulate the fluctuation (some send a fixed voltage)... ECU is not happy with a fixed voltage, it needs the fluctuation.
I'll try more in next days to solve my problem with a multimeter!
tricking the TPS will change the load that the ECU sees so it will change ignition timing too... you need to check HOW MUCH
