Ok so I rebuilt my turbo and re ran the oil feed today, after I plug in the new FMU and get it running tomorrow I'll take pictures.
I have a question. I'm looking at doing the same on my M42.
I haev found some 30lbs injectors that I plan on using, I have a Garrett td04-11B from a 524td and I'm gonna use a manifold from an M50 that I'll modify.
For the fuel pressure, do I only need an FMU or do I need a fuel pressure regulator on the side as well, I seem to see both solutions, what is the best to be able to tune it a minimum.
I'll be running a stock ECu btw.
Thanks a bunch
