Okay: 91 M42, 80amp Bosch Alternator.
Symptoms are/have been, at times the dash warning lights will stay on after the car is started, yesterday it showed an ABS fault until I stopped the motor and restarted it. Battery warning light will not illuminate with key in run (motor not running) but it will pulse when car is being cranked. It is not lit while motor is running.
Voltage at battery is 11.87 volts with motor off, 11.68 volts with motor running. So I know the alternator is not functioning. The question I have is, why is the charge light behaving like that, and does it have any bearing on the alternator problem, or is it caused by a fault somewhere in the alternator.
