Any tips on how to remove the valve cover and reinstall? I'm basically looking for general info about the project, just anythign you guys have from experience, is it hard to do, etc. for the tecnical stuff ill check out my bentely manual once i get home. The reason is that i need to set in a loose/stripped screw, even after two other just got new hardened steel sleeves yesterday. I talked to a BMW tech, he said i was fine for now but that i should go through and redo them all. he said something about a time-sert, and replacing each of the little rubber pieces on the screws. i took the loose one out for now so i dont loose it on the way up to oregon...wish the car luck...
Any tips/suggestions from previous experience? is this fairly easy to do? thanks guys
