People, please do a little research, I know its easier to ask first, but, it gets a little annoying to answer the same questions all the time...
Anyways, With the M47 crank, you can use M40 rods(135mm), S52 rods(135mm), M42 rods (140mm), M44 rods (140mm), maybe rods from M50, but not sure on this one...the stock pistons sit 0,15mm above block deck(TDC). and yield 10:1 CR,
With the M47 crank, and same rod lenght(140mm) and same piston (stock M42), the piston would be 3,65mm above deck (Impossible to work, would have to be shaved at least 3,5mm), shaved to 0 deck height would have 10,6:1 CR
With 135mm rod,M42 piston, and no shaving, the piston would be about 1,35mm below deck and 9,3:1 CR but only with 1951cc.
With 135mm rod, S52 piston(86,4mm) and no shaving, the piston would be 1,35mm below deck, 9,8 CR, and 2064cc.
