Nice. When you ordered your MM stuff, did you consider using their single row timing chain? I'm trying to find out if they even sell it separate from one of their built engines.
euro S38 timing chain: 11311401379
crank sprocket: 11311305396
intake sprocket: 11311305391
exhaust sprocket: 11311305392
available at
http://www.ecstuning.com for around $300 i think, bmaparts.com didn't list it, can't access fap99.com from work. I think you need the correlating dowel pin and spring washer as well. check realoem.com for more details
anyone know if the s38 lifters will fit in our m42 head, or what solid lifters MM is offering in their kit?
